Old 02-02-2011, 06:59 AM
PolarisATV300's Avatar
Member #9408
Quick 3 light Mod wiring question
Im having a issue finding the GREEN wire in the pod area. Please see below.
Relay terminal #30 connect to Polaris green wire - Is this the green wire thats going to the low beam lights? I just want to make sure before I trace it down from the front headlight and tie into it.
Thanks!
Old 02-02-2011, 10:27 AM
TimberGhost's Avatar
Member #9993
Yes the green wire is the one that goes to your low beam lights.
2002 Polaris Sportsman 700 Twin.
3 headlight MOD with relay / Symtec Hand Warmers
Cycle Country Mid Mount Plow
Old 02-02-2011, 05:25 PM
elmerkit's Avatar
Member #3805
Yup the green wire is the positive wire. just make sure to tap very well on that specific wire.
Old 02-02-2011, 06:00 PM
Member #9408
Thanks guys!
Old 02-06-2011, 11:48 AM
bgirard420's Avatar
Member #11494
How did you make out, are you up lighting up the night now? I originally did the diode mod, but after hearing all your discussions I decided to order a relay. I plan on doing it up next weekend and wanted to be sure the wiring worked out for you. I think I'll be fine since antonio who posted on your orginal thread has got the same bike I do and he listed that wiring plan too.
30----> green lo beam
87----> red power (mines orange and white 12 volt outlet)
86----> yellow hi beam
85----> brown ground (from 12 volt outlet)
This is how you did it, correct?
When I do it, I am going to make a you tube vid and post it up here.
Thanks!
2010 Sportsman 500 H.O.
Old 02-06-2011, 02:08 PM
Member #9408
Thanks!
Its funny you posted this today. I just got back into town and wired up the 3 light mod and went great! You are correct on the relay numbers with the wire colors.
3 Light Mod
By buckmaster at 2011-02-06
Old 02-06-2011, 05:37 PM
bgirard420's Avatar
Member #11494
Sweet, looks great! Looking forward to doing mine next weekend, and knowing that the relay isn't going to fry my switch.
2002 sportsman 700 high low light mod
atv light wiring
atv lights what is the green wire
atv low lights
connecting atv lights
green wire polaris
how to wire atv lights
polaris 3 light mod
polaris 3 light mod with relay
polaris 425 wiring
polaris headlight 12volt or 24?
polaris hi low light wiring
polaris hi/lo relay
polaris high low lights
polaris three light mod wiring diagram
sportsman 700 headlighr wiring
video of conncecting the high and low beam lights on a atv
wiring atv lights
wiring lights on an atv
wiring up lights on a atv
Quick carb question JoshH ATV Repair and Maintenance 13 12-04-2010 04:56 AM
Quick question 04Predator4408 ATV Repair and Maintenance 9 11-25-2010 06:04 PM
Quick Question 04Predator4408 Polaris Predator 2 11-24-2010 05:57 AM
Quick question The_Juice ATV Repair and Maintenance 2 11-22-2010 02:24 AM
Need some quick help with a simple question 03stage2 Polaris XP 5 09-23-2010 06:31 PM
