Old 03-07-2011, 06:31 AM
ohioheader's Avatar
Member #12698
Trunk/Storage box
How do I remove the front storage box lid? It is a 2010 500 Sportsman. I have the Polaris front brush guard/bumper, do I have to remove that? I can't see any pin heads if they are slip in or bolts in the hinge covers. Thanks.
Old 03-07-2011, 07:26 PM
Old 03-08-2011, 03:33 AM
gregv92c's Avatar
Member #3001
Do you just want to remove the lid, are the whole box ? I removed the whole box to install my ATV Guru brush guard .
Greg Smith
2009 Sportsman 500 HO
Glacier II Plow , Warn 3000 winch , winch saver
Rear grab bar , Polaris hand guards, HD Springs
Front rack extender , ATV Guru Brush guard
12X7 ITP Delta wheels, 27X9X12(F) 27X12X12(R)Mud Lite XL
Nerf Bars from Outlaw Fabrications , Maier fender flares
1996 Trailboss 250
Old 03-08-2011, 04:44 AM
Member #1958
You have four (each side) torx screws each side that tie it to the fenders. Two on top recessed by the latches and two under the fenders. Then there are two (I think) or maybe four 1/2" bolts inside the bottom of the box holding it to the frame. The whole box then comes out. The lid just has pins that slide into the box hinge. You don't have to take the bumper or brush guard loose.
Old 03-08-2011, 07:11 AM
ohioheader's Avatar
Member #12698
The lid
Just removing the lid for replacement. I rolled it and broke the back left corner. I can not see where the pins slide through the hindges. Do I have to pry back the hindge covers, there is nothing on the inside of the box that I can see. When the garage warms up I'll be working on it, maybe later today. Thanks Polman
Thanks Bruce, I've been looking for a good forum site. Not bashing them but Polarisriders.com has a lot to be desired.
Old 03-08-2011, 08:57 AM
Member #1958
The pins are held captive by the front bumper which houses the headlights etc. They just slide out. You can either remove the whole front end (PITA)....OR you can take the whole box out in about 10 minutes leaving the front end in place. It's really your choice but trust me it's really way easier to remove the box. Like I said earlier, there's only 8 screws and 2 or 4 bolts...simple!
Old 03-13-2011, 11:57 AM
ohioheader's Avatar
Member #12698
Storage box lid
Thanks Polman500, It has 4 bolts to the frame, 4 screws in the rear on top & 4 screws underneath to the sides. I have the winch distributer in the box so I only lifted it with a 2x4 high enough to push out the hindge pins.
Old 03-14-2011, 04:28 AM
Member #1958
Glad I could help. The way that hinge is made is not obvious just from looking unless you've had it apart before.
07 sportsman 500 front trunk
2011 polaris sportsman 800 storage trunk
atv guru trunk box
how do you remove front storage from 2011 polaris 500 ho
how do you remove the front box on polaris sportsman atv
how to remove front rack and fenders sportsman atv polaris
polaris 2010 sportsman front trunk lid
polaris atv front trunk
polaris atv storage box
polaris atv storage trunk
polaris atv storage trunks
polaris atv trunk
polaris front black box lid
polaris sportsman trunk
polaris storage boxes
polaris storage trunk
polaris500trunk
remove front box 2011 polaris
repair polaris rear cargo box hinges
video of how to put the pin hinge in side the front box on a sportsman 800
looking for a storage box jroptop Polaris Sportsman 0 02-16-2011 05:01 PM
Need Storage Box(es) CMDux Polaris XP 11 02-03-2011 04:29 PM
Storage Doty Polaris Sportsman 0 01-23-2011 08:26 PM
Lock and Ride trunk $100.00 ShortBus ATV Parts for Sale 3 08-31-2010 12:48 PM
Storage Box maverick11 ATV Repair and Maintenance 3 03-25-2010 05:42 AM
