Old 03-12-2011, 05:02 PM
aasu03's Avatar
Member #11856
How to wire additional lights through my switch
I bought some additional 55 watt lights from Wally-World and I wanna wire them so that when I turn my low-beams on they come on too! I'm electrically challenged... Please advise!
JT
Old 03-12-2011, 09:56 PM
cwlongshot's Avatar
Be Careful not to overload the switch!! The ONLY way I would do this is to run a relay. This will allow you to use the factory switch and not run all the power to light the lights thru the switch.
A relay is a small box with 4-5 wire terminals. One wire is ground, a second is fused power. These go to the battery. Third is a "trigger" wire. This one will be attached to the power side of the light you want to go on with your new lights. The last one (Or two depending on your relay) goes to the lights power side. Then you will need to ground the other side of the lights themselves. (Blk lead) and you have lights that will go on ONLY when what ever you attached the "trigger" wire too.
Good luck,
Old 03-29-2011, 09:08 AM
DavTay's Avatar
Member #10823
Send a message via Yahoo to DavTay
Good luck,
I need to add lights to mine. The front lights are missing. I want to add those cheap 55 watt lights. Way cheaper than finding used lights. Especially since the PO cut off the light plug.
Does anyone know the rating of the switch? the bulb for an 02 Magnum says 30/30. so is this 60 watt for high beams?
Can i just run the 55watts off the low beam setting.
Maybe one bulb on low and both on high?
Old 04-02-2011, 05:11 AM
ohioheader's Avatar
Member #12698
extra lights
I had mounted 2 55 watt lights on the front rail but used an extra water proof rocker switch, worked well and did not get into the main wiring system. Just a hot wire with an inline fuse and a ground. But then make sure you mount them with a rubber cushion or they will vibrate and won't last long, bulbs break.
Why is it the police never think it's as funny as you do?
2010 Sportsman 500HO
Polaris front brush guard
Front rack extention
Ricochet A-arm Armour
Promark Rear bumper
2500 warn winch
KFI 60" plow
Reverse over-ride
Mad Dog rear bag
Lots of deer blood
Old 04-02-2011, 07:24 AM
DavTay's Avatar
Member #10823
55 watt bulbs draw about 4.6 amps.
Looks like a 22 gauge wire will handle 5 amps.
Some switches are not designed to handle much of a load thats why we use a relay.
2 55watt lights on a atv
atv cop lights
how to ground lights for atv
how to install wiring for lights on a polaris atv
how to polaris wire extry lights
how to wire a light on a utv
how to wire a n additional light
how to wire an atv for brake lights
how to wire atv driving lights
how to wire atv lights
how to wire brake lights on an atv
how to wire light switch for atv
how to wire lights atv
how to wire lights on atv
how to wire lights on atv do i want a relay
how to wire police lights on atv
how to wire sportsman lights
how to wire strip lights on atv
polaris phoenix blue wire
polaris phoenix wiring diagram
wire diagram 90 help erice ATV General Discussion 2 08-10-2011 06:06 PM
cdi blue wire ? scotmo Polaris Scrambler 0 08-16-2010 03:05 PM
Loose wire..help!!!! 96xpress400 ATV Repair and Maintenance 1 08-09-2010 05:13 PM
wire pigtails deantrickster ATV Repair and Maintenance 0 05-18-2010 06:12 PM
Additional help needed for battery not staying charged. ldgraf Polaris Phoenix 3 06-06-2009 06:47 PM
