Old 04-18-2011, 09:47 AM
mngatorhunt's Avatar
Member #13020
Rear?Front Utility Box
Any ideas on a galvanized rear utility box for a 850 XP. I like the look of the black truck tool boxes, but I don't need anything that wide. I am going to bolt it in to the rear rack and also add a back rest to it... Any ideas or pictures of homemade utility boxes?
Old 04-18-2011, 10:07 AM
MNPolaris850XPeps's Avatar
Member #11395
any idea on what dimensions you want?
POLARIS 850 XP W/EPS pure polaris hand guards and front lock and ride box, RICOCHET front and rear a-arm gaurds all lifted up on 27" GBC SPARTICUS tires on ITP system 6 rims, uni air filter and fender flares on the way
Old 04-18-2011, 10:22 AM
Member #13020
I want to cover the entire rear rack if possible. Not sure but maybe 42"x24"x14"... Something along those lines. What do you have in mind?
Old 04-18-2011, 10:39 AM
Member #11395
id recommend 37x13x14 i mad a box out of thicker plywood this winter (wish i had pics) mine was about the size i just said idk if you do much ice fishing but with these dimensions i could fit three buckets in side by side rather easily i drilled holes and used my lock and ride mounts but bolting it in would be a much better idea i'd go with this first and see how you like it before making anything to expensive but if you do like it i'd find some diamond plate then bring it in to a local welder or fabricator and have him make it about the same size im fine with the wood one but if you wanted something that would really last that would be the way i would go you could even make a lid for it if you wanted and as far as the seat goes id just attach it wherever it feels comfortable with some screws.
Old 04-18-2011, 10:45 AM
Member #13020
Here is a box that I found on the internet that someone has. I want the same setup except on one side I want to be able to hold a gas can and on the other side I want to have a chainsaw mount...
I really like the idea of the (3) buckets, I do nothing but ice fish and plow with my atv during the winter. I also want to have a holder on the top of the box for my Jiffy 10" Auger...
Old 04-18-2011, 10:53 AM
Member #11395
that looks pretty slick i might have to make something similar for trail riding this summer cooler in the middle with two gas cans on either side as far as your auger goes i put the gun racks in the front of mine and my auger slips in nicely.
http://www.polarisatvforums.com/foru...ture1999-a.jpg
Old 04-19-2011, 03:47 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
I use a heavy duty black plastic utility box I picked up at Walmart for less than $20. It's 32"x18"x13" with a hinged lid, rugged clasps, and can be padlocked.
Old 04-19-2011, 04:27 AM
Something about sharp metal edges on a ATV scares me! Would hate to be in a accident and have something like that land on me. That is why I prefer plastic rounded edges.
Old 04-19-2011, 06:44 AM
Member #13020
Thor, I think we must have totally different riding styles. This box will be used only for utility purposes when out clearing trailing, hunting, and ice fishing. I like the plastic boxes, but just not for this application. I probably will end up getting a front lock and ride, but unfortunately I will need to customize a box for the rear that I can use for all my needed applications...
Old 04-19-2011, 07:12 AM
That is understandable. I do see lots of people using metal boxes and ammo cans while doing some crazy things and think that would hurt if it landed on top of them. ;-)
ammo can atv
attach wood box to front rack of atv
atv ammo can
atv homemade rack box
atv utility box
diy atv back rest
diy atv rear seat
diy rear seat for atv
homemade atv back seat
homemade atv box
homemade atv boxes
homemade atv icefishing boxes
homemade atv rear basket wooden
homemade atv rear seat
homemade rack box for atv icefishing
polaris atv rear utility box
polsris sportsman utility boxes
utility trailer modifications
wood atv boxes
wooden atv box
Torc utility slip on for sportsman 700 QuickSilver74 ATV Parts for Sale 5 04-29-2011 05:56 PM
rear wheels for front and rear??? krzykrakr Polaris Sportsman 5 04-19-2011 01:56 AM
Utility trailer for sale SNW629 ATV Parts for Sale 7 11-17-2010 02:15 PM
Side-Loading on a Utility Trailer Bionic Man ATV General Discussion 5 03-08-2010 07:49 PM
FS: BRAND NEW LRD Torc Utility Series Muffler - Sportsman quickbiscuit ATV Parts for Sale 3 01-18-2010 08:26 AM
