Old 05-04-2011, 07:21 PM
notdaddys's Avatar
Member #14745
3 light system
i found plenty of ways on how do to the 3 light system on this site and a couple other sites. when i bought my atv it had that diode version. and when i installed my 8000k 35 watt hids it worked for about a week and then started working the way the factory intended it to (2 lights on lows and the pod high) so i decided to do the relay version thinking the diode went bad or something (idk if thats possible or not) when i used the relay and the info from this thread: Convert To 3 Light System - Can-Am ATV Forum. it still worked as the factory made it. i was wondering if it was because the power that the ballasts draw or if there was a fuse or something i could have blown or if i need a bigger relay. any help would be greatly appreciated.
thanks
-Seth
Old 05-09-2011, 07:53 AM
notdaddys's Avatar
Member #14745
anybody?
Old 05-09-2011, 01:33 PM
michaeltucker01's Avatar
Member #4949
You might want to post this on the ATV Repair and Maintenance Board its alot busier, I would like to help you but I don't have any experience with the three headlight mod
2010 Sportsman 550 XP
Polaris 2500lb Winch
Polaris Lock and Ride Front Cargo Box
Polaris Mid Lock and Ride Front Windshield
Polaris Rear Rack Extender
Polaris Deluxe Front Brush Guard
Ricochet A-Arm Guards From www.theatvsuperstore.com
14 inch Maxxis Bighorns Mounted on SIXr Wheels
Old 05-09-2011, 06:10 PM
notdaddys's Avatar
Member #14745
thanks for the advice
2005 sportsman 800. *66inch v plow*heated grips*2500 warn winch*detachable windshield*8000k hids*itp mudlites*
Old 05-09-2011, 08:36 PM
pathfinder's Avatar
Member #10066
With a meter put the black lead a good ground ( neg. side of battery if leads are long enough) and unplug the wire that is on terminal #30 on the relay. Put the red lead from the meter on the #30 pin on relay. Now turn key on and switch the lights to high beam. You should now have 12 volts reading on the meter. If you do not, it is either wired wrong or you lost the 12 volts on pin #87 (due to a blown fuse or bad splice). While you are at it make sure pin # 85 has a good ground. I am assuming the relay numbers are correct, I am going off the post you have attached. I did mine so long ago I can't remember the relay numbers and which wires they go to. Good luck.
2010 Sportsman 500 HO
3 headlight mod (with relay)
rear rack extender
handguards
Warn XT25 winch
Ricochet arm guards(anodized black)
Polaris front & rear brushguards
LED tail lights www.autolumination.com
HID light kit http://www.theatvsuperstore.com/ATV-HID-Lights-s/54.htm
Old 05-10-2011, 08:19 AM
notdaddys's Avatar
Member #14745
thanks i will try it tonight. thanks for the info.
Old 05-11-2011, 08:18 PM
08TouringLE's Avatar
Member #12162
Your best bet would be to use a relay setup to supply power to the lights. it's not a difficult modification and it allows a full 12v to flow directly through the relay to the lights rather than going through the switch. The headlight switch would basically turn the relay on and off. I read on some other forums of people having trouble with the headlight switch failing as it was not designed to handle the load of having all 3 lights on at the same time. Don't know if this is a problem, but I felt I would rather be safe than sorry and use a relay rather than a diode setup. I also made the "backup light" mod that allows my "worklights" to function as reverse lights. Great for on the trail in a group as the lights come on and serve as a warning that I'm going to back up. Also good for plowing snow at night, so I don't have to turn the worklight switch on and off.
Big Gun ECO system? jackstrx ATV Performance Modifications 7 01-31-2011 07:24 AM
System 6's on your xp? MNPolaris850XPeps Polaris XP 0 01-27-2011 10:55 AM
AWD Switch and System Clayberd ATV Repair and Maintenance 6 01-10-2011 12:57 PM
500 EFI Plow System eclifford634 Polaris Sportsman 7 12-09-2010 08:21 AM
Starting system on 00 500 JoshH Polaris Sportsman 3 08-14-2010 05:38 PM
