05-08-2011, 09:40 AM
Member #11963
Rhino Coating?
Has anyone on here sprayed their plastics with this stuff? I've heard alot of 'it won't stick to plastic', but I have a shop teacher who owned a dirt bike that was covered in the stuff. He said it was great for trailing. I recently painted the plastics with a cheap version (rubber undercoating) on what's left of my little xr. It looks quite nice, jus waiting for the epoxy I used to piece the casing of the bottom end back together to harden (I know there is going to be a comment of how it wont hold and just buy a new one, but it is a beat up bike where if something is wrong I head to the junkyard. And I've used this epoxy stuff before on a bottom end, lasted 4 years of hard riding  ) Anyway back on subject, I'm tired of looking at my dumb yellow plastics and heard that this stuff makes a big difference on tight trail where you are constantly bumping into trees and what not. For me looks aren't key, I mean the bike is a trailblazer (can't get much uglier than that in my opinion), all I care is that the bike can take a beating and won't come back with yellow streaks shining through.
05-08-2011, 11:20 AM
Member #10988
Box liners are typically a urethane formula and tend to stick very well if the surface is properly prepared. Plastic is a finicky surface but it is doable. I would recommend cleaning the plastic with a plastics cleaner thoroughly then sanding the plastic with a coarse sandpaper, probably 80-120 grit. Then clean again and now the plastic will be ready for the boxliner. The box liner will stick due to mechanical adhesion and I don't think it will peel as box liners are very tough and durable. Once its on it's on for life...
2007 500 H.O. X2 stock with Swamplites (gone)
2 - 2007 Hawkeyes, 10 gr. clutch rollers, 12 in. Razr take-offs w/ stock Maxxis, Aux. oil coolers, 3/16" aluminum skid plates (gone)
2007 Yamaha Grizzly 700 fi eps Limited Edition -stock for now (only one left )
05-08-2011, 02:29 PM
Member #11963
Well I definately don't want it to come off, the plastics on the bike are so beat up as it is, that I think this will be a big step up. There is a guy coming to spray our 42' boat with rhino lining in a couple weeks. So I'm thinking I will take your advice with the tough grit sandpaper and just take the plastics to him.
05-08-2011, 07:19 PM
Member #10988
Post your results and let us know how it worked for you.
05-11-2011, 07:58 PM
Member #12162
Recently, I mentioned this same idea under the thread "Keep it blue" in this forum. I suggested it, because of a man I know here in town that had his work truck "painted" with the Rhino coating, it came out looking pretty good and seems to stand up well against scratches and other minor damage. I thought it would be a good idea, if it would stick, for ATVers who really ride their machines hard and need some protection and are not concerned about a "factory look paint job".
05-11-2011, 09:44 PM
Member #11963
Finished with the fenders on my xr, turned out quite well....definately better than any soray paint, gives it a tougher look and seemed to cure quite well on the plastic.
05-12-2011, 03:01 AM
Member #5629
Con
05-12-2011, 10:09 AM
Member #11963
Here's the Xr with fenders coated
They should be uploaded, and how do you guys do all your signatures? Is it just copy and paste every message or?
05-12-2011, 04:06 PM
Member #2620
Looks nice. How does it stand up to flexing the plastic?
95 Magnum 425 4X4
05-12-2011, 04:17 PM
Member #11963
They hold up surprisingly well, and hardly scratch at all, and these were plastics that had been scrounged up. So if you had seen them before you would have been amazed. I also threw on a couple coats of paint. Planning to do the side plastics next. And when I finally get to a store (I live in a rural part of Alaska) I will buy enough for my trailblazer.
atv fender coating, atv plastic paint, atv plastic rhino liner, atv rubber coating, does rino liner stick to rubber, is box liner tougher then under coat, polaris ranger under coat, rhino coated atv, rhino line atv plastic, rhino lined atv, rhino lined atv plastic, rhino liner atv plastic, rhino liner on atv, rhino liner polaris, rhino lining atv plastics, rhino rubberized covering, rino liner on atv plastic, undercoat atv plastic, undercoating atv plastic, will rhino lining stick to plastic
