Old 06-07-2011, 04:26 PM
Bruce500's Avatar
Member #15599
cutting fenders
how the hell do people cut the front fenders on there predators? I wonna do it but definetly don't wonna mess it up? any suggestions?
Old 06-07-2011, 05:58 PM
Bruteforcebob's Avatar
Member #14933
Tape the cut you want then use a cut-off wheel
Old 06-07-2011, 06:01 PM
Member #14933
Follow the tape while cutting and use a propane torch to heat and smmotg edges
Old 06-08-2011, 08:46 AM
ohioheader's Avatar
Member #12698
Plastics
Make a paper template and flip it from one side to the other, so as to cut both sides the same.
Why is it the police never think it's as funny as you do?
2010 Sportsman 500HO
Polaris front brush guard
Front rack extention
Ricochet A-arm Armour
Promark Rear bumper
2500 warn winch
KFI 60" plow
Reverse over-ride
Mad Dog rear bag
Lots of deer blood
Old 06-21-2011, 07:30 PM
elmerkit's Avatar
Member #3805
Yes tape and a saw will will do the job.
Old 07-04-2011, 06:55 PM
rakoon's Avatar
Member #16375
Why Cut?
Hi,
Why do you cut the fenders? Is it to put bigger tires under there and avoid hitting the spot where the fender and flairing bolt together?
I have a 2002 Polaris Sportsman 700 and am considering cutting the fender to the other side of the seam, then put on some flat extensions going straight out without a "seam" between the 2 parts (fender and flair)
I am 'considering' this because I bought 28" Maxxis Zilla's and they will rub unless I lift it. would like to avoid the lift, am trying to sell the tires, but if I don't then I have to come up with something to make it work, hoping a 2" lift on the front only will resolve.
Anyways, just curious on why you cut the fenders if it is not the same reason as what I am describing.
Old 07-04-2011, 07:17 PM
Member #14933
When racing atvs through the woods it helps avoid snagging limbs it also gives a direct view of the line your running to better judge the track
Old 07-30-2011, 11:38 AM
croghan23's Avatar
Member #12402
tape, jig saw, and sand paper...tape down a crease in ther fender and cut it and they will be even
2008 Outlaw 525s
-renthal fat fars
-pure polaris nerf bars
-baffle removed
-shaved fenders
-red neon lights
2008 polaris outlaw 525 cut front fenders
are the 2008 outlaw and 2009 fenders interchangeable
cutting atv fenders
cutting fender on atv
cutting fenders on polaris predator
how to race cut a prediter 500
polaris 500 race cut fenders pictures
polaris outlaw cut fenders
polaris predator 500 race cut fenders
polaris predator cut fenders
polaris predator cut plastics
polaris predator fender cut
polaris predator plastics cut
polaris predator race cut fenders
race cut predator fenders
racing cut fenders for a predator 500
sportsman 700 cut fenders
trimming atv plastics
why do people cut fenders on
AWD cutting out mininjack Polaris Sportsman 2 04-26-2011 02:40 AM
painting plastic fenders intermet Polaris Predator 4 02-02-2011 04:13 PM
gen 5 vs gen 6 fenders and plastic interchangeable? PA_Probe ATV Visual & Body Modifications 6 08-13-2010 05:52 AM
2002 Trail Boss Fenders? Drummer89 ATV General Discussion 2 11-14-2009 01:20 AM
what to use on the rubber/plastic fenders? krazybob ATV Repair and Maintenance 10 11-08-2009 03:56 PM
