Old 06-22-2011, 07:58 AM
aaronsink12306's Avatar
Member #15947
Arrow trailboss 325 HID Conversion?
Was wondering if anyone has ever done this and if it worked well ? I have a 00 trailboss 325 that the stock light just isnt cutting it for me so I was thinking of either doing the conversion or possibally adding a set of driving lights that would be used for the low beam and than on high beam the stock light would come on along with the 2 new driving lights although not sure how to wire this one up any help would be great
Old 06-22-2011, 10:19 AM
Old 06-22-2011, 10:26 AM
Member #15947
thank you
Old 06-22-2011, 12:34 PM
Contact a member on here by the name of Thor. He owns the atvsuperstore and can probably set you up with HIDs
Old 07-07-2011, 05:50 AM
stefanj's Avatar
Member #10741
I think the question here is will the machine handle HIDs My 03 Magnum has a 200 watt output capacity, not sure what the 325 engine put out. Take all your current electrical usage items, add up the wattage consumed, and you'll have a good idea of what you can safely add (allow a 10% margin of error just so you don't overload the voltage regulator).
03 Magnum 330 4x4 Mossy Oak
Cycle Country 48" plow
Superwinch LT2000
GuideGear rear drop rack basket
Koplin seat cover
Front and rear rack bags
rear tire chains
rear work light (walmart)
8 acres of personal riding space
Old 07-07-2011, 06:45 AM
Member #15947
I was always under the assumption that the HID's only used alot of current when they were first fired up and that if their was a battery in the circut that it would draw the extra needed current to fire from that and not the out put from the stator?
I currently have just the stock head light 60/60w bulb the tail light and the oil cooler fan running off the out put from the stator and that a set of cheap aux driving lights which are 55w a piece running directly to the battery so thats not affecting the draw off the electrical system at all. and the HID's would be replacing the stock head light so the only thing running besides the HIDS would be the tail light and oil cooler fan and them combined I am pretty sure are no where near 200watts. and I Was thinking of using a Motor cycle HID kit being its designed for a smaller electrical system and being the trail boss only has the one head light I wouldnt need the dual kit like the guys putting them on the sportsmans or such....
Old 07-07-2011, 06:57 AM
stefanj's Avatar
Member #10741
Should work. I'm not real fimiliar with HIDs and their wattage requirements, but if your using Motorcycle lights- you won't have any issues as most bikes electrical systems are similiar in design and draw as our ATVs.
Superwinch LT2000
Koplin seat cover
rear tire chains
Old 07-07-2011, 07:10 AM
Member #15947
thats what I am hoping anyway lol I sent Thor a message on here about the sportsman Pod HID Kit and was wondering if that could be made to work or not just waiting for a reply before I go looking for other routes with the Motorcycle Kits cause that would be a night mare in trying to figure out how to wire them in lol and I cant find any good schematics for this machine anywhere lol but thanks for the input stefanj
Old 07-08-2011, 04:39 AM
stefanj's Avatar
Member #10741
No Prob! Thor should get you squared away. He's a dealer but I got a lot of respect for him as he contributes so much info and offers up solutions that his company may not carry. Gotta respect I guy who does it for the love of the sport.
Superwinch LT2000
Koplin seat cover
rear tire chains
01 polaris trail boss hid conversion
02 polaris trailboss 325 mods
8acrepodkit
adding headlight to trail boss
does a polaris 325 trail boss have headlights
headlight polaris 325 trail boss conversions
hid kits for polaris magnum 330
hid lights polaris magnum 330
mod your atv for polaris trailboss 325
polaris 325 trailboss light bulb specs
polaris trail boss 325 4x4 conversion
polaris trail boss 325 coolant
polaris trail boss 325 headlight bulb part number
polaris trail boss 325 mods
polaris trailboss 325 headlight bulb
polaris trailboss 325 netural light bulb
trail boss 325 four stroke
trail boss 330 volts lights
what kind of headlight bulb does a polaris 330 trailboss
2 stroke pre mix conversion kytitan ATV Repair and Maintenance 15 04-07-2012 01:42 AM
2-up conversion sportsman700 Polaris Sportsman 11 07-31-2011 09:33 PM
Conversion Cslaxer26 Polaris Sportsman 6 05-05-2011 02:57 PM
ATP bed to rack conversion semprfi ATV Visual & Body Modifications 4 02-09-2011 05:06 PM
'99 Diesel Conversion rjrkihap ATV Repair and Maintenance 2 11-02-2009 11:31 AM
