Old 07-17-2011, 04:00 AM
TNWB's Avatar
Member #13310
Ricochet A-Arm Gaurds - Install
Installed my new Ricochet front arm guards last night: First let me say I was impressed with everything right out of the box except the very primitive instructions for installing. I'm the kind of guy that actually likes to read the directions on how to put something together. Only problem I had once figuring out how to mount them was I striped the smaller bolt head on both sides. I'ts the bolt that threads into the same whole the original plastic gaurd was mounted to. The bolts have the Torque heads on them. I thougth after stipping the first one I would be more gentle on the second one but I barely got it tight (lock washer compressed) and stripped the second one also. Only using a very small 1/4in socket wrench. Anyone else have this issue? Luckily I don't think the rear ones have those smaller bolts and the rest of the install will go smoother.
2011 Polaris 850X2
Polaris 2500lb Winch
Ricochet Front & Rear A-Arm Gaurds
Warn ProAdvantage 60in Plow
Symtec Heated Grips&Thumb
1987 Kawasaki 250 Mojave (sold 1988, 23 years to get another one )
Old 07-17-2011, 05:28 AM
xp74's Avatar
Member #4807
I stripped those two bolt heads also.
2010 550xp
Old 07-19-2011, 09:19 AM
ohioheader's Avatar
Member #12698
Ricochet arm guards
I wrote a note to Thor saying the lower or outter rear bolts need to be at least 1/4 longer. The arms were clean and the bolts were just too short. He wrote back and said he would mention it to Ricochet.
Why is it the police never think it's as funny as you do?
2010 Sportsman 500HO
Polaris front brush guard
Front rack extention
Ricochet A-arm Armour
Promark Rear bumper
2500 warn winch
KFI 60" plow
Reverse over-ride
Mad Dog rear bag
Lots of deer blood
Old 07-19-2011, 02:47 PM
TNWB's Avatar
Member #13310
I haven't started the rear yet. I spent last night getting the stripped bolts out of the front. I wanted to do it now instead of some time in the future when they are rusted and harder to get out. I was successful and realized that I stripped them out because they weren't torx bolts but hex. I assumed that since the bigger ones were torx that the smaller ones were too. Had I been working in the day light I would have probably not made that mistake.
2011 Polaris 850X2
Old 07-29-2011, 07:22 AM
DirtFiend's Avatar
Member #16495
buy some self tapping screws oversized slightly they are usually aluminum or soft steel sometimes have that soft rubber washer on them to prevent water leaks for use when using them to hold a tin/corrugated roof to steel tube/pipe.
2012 Polaris 500 H.O Orange Madness. Rear Rack Extension , 3 Headlight mod, ODI Rogue lock-on Grips , Acerbis Uniko handguards , Uni Air Filter , Viper Winch and a kolpin rear multi hitch. have not picked a wheel/tire setup yet looking at the new itp ss316's
2011 Polaris Trail Boss 330 "needs some performance upgrades"
2007 Yamaha Raptor 700RSE Extended Swing Arm Billet Levers,Foot Pegs,Clutch,Flywheel,Shifter
FMF Powerbomb exhaust and pipe/header I could go on and on but my sig would be 3 paragraphs long
Old 07-29-2011, 07:49 AM
Hawkeye 007's Avatar
Member #8077
You don't tend to tighten screws so tight if you put a drop of blue loctite on them before you tighten them. Plus you don't have to worry about them vibrating out.
2011 Red Touring 850
Ricochet A-Arm guards
2011 polaris trail boss 330 rear bumpers
how to install front a arm guard on polaris atv
how to mount ricochet. a arm guards
how to put a arm on atv trail boss 330
installing ricochet a-arm guards
polaris ricochet arm
polaris ricochet front & rear a-arm guard set
polaris trail boss 330 2011 brush gaurds
problem with richochet armor on 850 touring
richocet arm guards install
ricochet a arm guards
ricochet a arm install
ricochet a arm instruction guide
ricochet performance a arm guards
thor rivochet a arm guards
Got the winch, tires and ricochet gaurds installed. Fuzznutts Polaris XP 2 06-20-2011 10:38 PM
would like to think Don at Ricochet skids crimson850 ATV General Discussion 4 02-10-2011 02:40 PM
Polaris outlaw 500-525 prm baja bumper & prm heal gaurds 126happy ATV Parts for Sale 4 02-01-2011 05:15 PM
A-arm gaurds KennethMoore Polaris Sportsman 4 08-19-2010 04:30 PM
hand gaurds? fatkidracer ATV Visual & Body Modifications 2 06-21-2010 05:47 PM
