Old 07-17-2011, 04:32 AM
cwlongshot's Avatar
Lightbulb Brighter Tail light mods
This will work for a number of models, but as far as I can tell, Early Magnums, Sportsman's, Trail Bosses and Scramblers all share this style light...
I noticed following my wife that the tail light was pitifully inadequate. Barely visible and only mediocre when brakes where applied. In comparison, Both a '07 Yamaha and Suzuki had very good tail lights. The Suzuki's was brighter when in running mode then the TB was with its brakes on and both used the SAME BULB!!
I pulled it apart and see that there is no reflective inside, only black plastic. Well as you know black absorbs light, doesn't reflect it. So I took some shiny metal aluminum duct tape and made up some reflectors.
I cut it to fit inside on the back of the light, behind the bulb.
Then I added some more to the sides of the red lens as I don't think its needed to be seen up under the fender or down at the ground.
I polished up the lens a bit with some Meguiars plastic polish used for cleaning plastic head lights. (GREAT STUFF!!) Then reassembled.
BEFORE;
AFTER;
Not a huge improvement, but better just the same. I had some of that "thousand mile" reflective tape too. But decided to try the shiny aluminum tape first...
lighting mod. polaris
polaris tail light mod
polaris tailight guards
polaris taillight
Right Tail Light bf750 Polaris XP 3 Yesterday 06:38 AM
LED tail light pics pathfinder ATV General Discussion 23 08-30-2011 03:28 PM
Tail light bcarfley Polaris Magnum 1 01-22-2011 04:44 PM
Tail light always on xfactor Polaris Sportsman 20 10-11-2010 07:48 AM
x2 tail light guards hvychevy ATV Visual & Body Modifications 3 06-10-2010 12:58 PM
