07-21-2011, 03:56 AM
Mud flaps/Fender extensions
I am going to make my own. I have a couple ideas but I wondered if any of you guys already blazed a trail.  I know there are flairs I can buy and I do like them. But for now looking for "home brewed solutions"
Post up your pics or jot down ideas!! I could use some help!!!
I'm tbinking of trimming down car/truck flaps to appropraite size and attaching to rear fenders. Would like to get something like those Yosemity Sam,"BACK OFF". Lol
For the front, again trim something down. I really just would like to limit the spray from bottom edge. The factory fenders/plastic work great at keeping me dry. But my box and side bags are getting soaked!!!
I'll post pics of what i come up with once I do it with in next couple weeks
07-21-2011, 12:24 PM
Member #1958
Hey CW...I ran across a bunch of info like you need on GEN3USA a while back when working on my bud's old scrambler. There's a link to a place with rolls of plastic like you need at reasonable prices that is used for stock car bodies. I ordered some and built him some flares and me some flaps to go on my 800.
oops the link didn't work but here's the address and search "fender flares"
Gen3USA :: Index
07-29-2011, 07:36 AM
Member #16495
whatever you do don't use stainless steel or any other steel or aluminum sheet to add flares/widen the fenders. unless you roll the edges I went to hop on my banshee one day and cut the heck outta my calve :-x
2012 Polaris 500 H.O Orange Madness. Rear Rack Extension , 3 Headlight mod, ODI Rogue lock-on Grips , Acerbis Uniko handguards , Uni Air Filter , Viper Winch and a kolpin rear multi hitch. have not picked a wheel/tire setup yet looking at the new itp ss316's
2011 Polaris Trail Boss 330 "needs some performance upgrades"
2007 Yamaha Raptor 700RSE Extended Swing Arm Billet Levers,Foot Pegs,Clutch,Flywheel,Shifter
FMF Powerbomb exhaust and pipe/header I could go on and on but my sig would be 3 paragraphs long
07-29-2011, 08:53 AM
Gen3USA :: Index
Thanks man, i just tried the link and its dead for me...
I
07-29-2011, 08:58 AM
OUCH!! Hope your ok?!?!
I actually DID use some Alum diamond plate for the rear extentions. Should not be problem as its back and beneath bumper.
For the front, I cut domn some flaps and bolted them to the front of the footwells.
Try them out soon...
07-29-2011, 12:05 PM
Member #13820
Looks good
2011 Sportsman 500 HO
KFI 3000# winch
Ricochet A Arm Armor
Rear Rack
Polaris Front Rack Extender
Viper 60" Plow
Moose Heated Grips
07-29-2011, 04:15 PM
Originally Posted by Natureboy
Looks good
Thanks man, Hope they keep momma clean (er)
07-30-2011, 05:47 AM
Member #12687
I added these...
I ordered flaps from JC Whitney and cut them down to fit (just make sure you buy the correct width). In addition to the photo, I have added extra screws/mounts (all are speed nuts).
Many rides since adding them with no trouble. Total cost = $19.00
2011 850 Touring - Mine; Richochet A-Arm Guards; front bumber from ATVSUPERSTORE.COM
2011 550 XP EPS - Hers; air horns
07-30-2011, 10:20 AM
Looks good, can you post larger pic... I can hardly see. I was hoping someone would post pics of a XP. Pop wants something too!!
Today I had to pull the rear bumper as I was lazy and didn't put pop rivets behind it. Well... don't ya know it rattles badly!! I pulled the bumper... never realized it was THAT heavy!!! It weighs nearly twice what my two up rack does!!!! SO I'm leaving it off! But I used it as a pull down when trailering to compress the suspension. SO, time to fab up a bar out back!!
Here is what I came up with, a 18" stick of 1x1/2"x1/8" thick steel. Two 1/4"x1" flat stock tabs and a bit of weld to hole it together. I drilled mounting holes in the tabs, Then I tapped two blind holes to attach another flap...
Then of coarse, Yosemite's was hollering at me cause I kinda dissed him with the diamond plate flaps... so one he went for "looks".
Looks OK what do you'll think?
07-30-2011, 11:37 AM
Glad you posted up!!
Could you post a larger pic? Its too hard to see your tiny one.
Pop has a XP and would like some too...
Today I added a center flap...
I wanted to put two more rivets in my rear flaps as they where rattling. I got lazy and didn't put them in originally. Anyhow, my bumper is WAY heavy!!! So i left it off. BUT I used it for compressing the suspension so I made up a short bar outta some scrap steel. I welded in two tabs and tapped two holes for the center flap. (flap is for looks I know its not gonna do anything.) The bar is nice to move machine and compressing suspension while trailering.
Tell me what you think!
2000 polaris trailboss 325 fenders, 2005 polaris 330 trail boss fenders, 2011 polaris atv fender extenders, atv make your own mud flap, atv mud flap extensions, best fender flares moose or kolpin, custom polaris scrambler mud flaps, how to build mud flaps for polaris 500 atv, itp ss316, make your own mud flares, mud flares polaris trailblazer, polaris atv mud flaps, polaris scrambler mud flaps, polaris scrambler mud guards, polaris trail boss fender flares, polaris trailblazer fender flares, putting mud guards on a polaris trail bosss, rear and front mud skirts for polaris scrambler, trailboss 325 mud skirts, yosemite sam mud flaps
