08-18-2011, 06:47 AM
Member #7892
Recommended paint for racks?
I'm looking for something strong that won't chip off or get scratched for both rear and front racks. Any recommendations?
08-18-2011, 06:50 AM
Member #13989
you could also get them powder coated? it shouldnt be much at all just to get the racks done
08-18-2011, 06:57 AM
Member #17544
Bedliner paint.
08-18-2011, 06:59 AM
Member #17443
I agree with the powder coating...that would look really good and wouldn't cost much.
I personally went with Dupicolor spray on bed liner. About three coats gives you a textured, durable coating; and since it's textured you can do spot-sprays as needed for touch-up without it being at all noticeable.
...the chrome won't get you home.
CNTRY
08-18-2011, 07:18 AM
Member #7892
powder coating is not an option for me at the moment.
How did you apply that duplicolor bed liner? spray can, brush etc?
08-18-2011, 07:20 AM
Member #17443
Spray can...nice even strokes at about 12" distance...3 coats. The trick is to keep the nozzle clean between coats otherwise it sprays a little funky and could produce a different texture for your subsequent coats.
CNTRY
08-18-2011, 11:18 AM
Member #7892
what about body shutz from M3, has anyone used it?
08-18-2011, 11:27 AM
Member #17443
I'm thinking that might be a little too 'soft' -- for lack of a better term. I've tried various 'rubberized' and/or 'undercoating' products on my truck and never had good results as far as durability is concerned.
I mean, they do what they say they do, provide corrosion protection and sound deadening, but this kind of product doesn't hold up well to harsh abrasion. If you scrap it against a rock or tree you'll be liable to dig right into it. And if it's like other similar undercoating products, it'll be hard to touch-up rough abrasions...that is, if you want them to be unnoticeable, because it gums up when you try to sand it.
Bed liner is prolly your best bet...or, if you never what to worry about it again, get it Line-Xed.
UPDATE: Of course...this article says it has better abrasive resistant properties then standard undercoating products.
http://www.hemmings.com/hmn/stories/...feature19.html
CNTRY
08-18-2011, 11:36 AM
Member #7892
also I found 3 types of brand/can spray available at autozone...
one is from Duplicolor called rubberized undercoating can spray. the other is just bed liner..they sell it in can spray and 1 qt bucket. I believe is from 3m as well.
Also our local paint store carries another abit more expensive that is supposed to be stronger but i cant remember the name. is from the same brand names mentioned above and the can label is in green colored
08-18-2011, 11:41 AM
Member #7892
Body Schutz | Hemmings Motor News
Thanks for the info.
I just bought Body shutz a few hours ago and a local body shop is going to spray the product with their tools. they highly recommended it. however I wanted to hear you guys opinion before anything...
atv rack coating, atv rack paint, atv spray paint, best paint for atv racks, best paint for fourwheeler so they won't chip, how to bed liner atv rack, how to paint an atv rack, how to paint atv racks, paint atv rack, paint atv racks, paint for atv racks, paint to use for atv racks, painted atv rack, painting atv racks, rustoleum vs duplicolor bed liner, spray painting atv racks, what is a good paint for atv racks, what kind of paint to use on atv rack, what kind of spray paint to use on atv racks, what type of spraypaint do i use on fourwheeler racks
