Old 09-02-2011, 03:16 PM
Natureboy's Avatar
Member #13820
Fixed my hitching problem
Had a bit of a problem hitching stuff to the back of my ride. Always pulled stuff around with the lawn tractor, so when I attempted to hook up to my sprayer/yard cart/dump trailer, everything was tipped because of the higher hitch mount on the quad. Solved that problem today. Had some 1 1/4" square tubing laying around from another project (the dumpcart & trailer for sprayer), and another piece of square tubing that fit into the 1 1/4". Works great, lower is for the sprayer & garden cart, higher is for the dump cart, just have to pop the ball in for the dumper.
2011 Sportsman 500 HO
KFI 3000# winch
Ricochet A Arm Armor
Rear Rack
Polaris Front Rack Extender
Viper 60" Plow
Moose Heated Grips
Old 09-02-2011, 03:21 PM
cwlongshot's Avatar
GOOD jOB, it looks great!!!!
I solved my hitching problems too.... I put a hitch on the FRONT!!! You would not believe how easy it is now to move things around on the property!!!!!
Old 09-03-2011, 08:53 AM
Natureboy's Avatar
Member #13820
Thanks CW. Next project is going to be a removable scabbard for the chainsaw.
KFI 3000# winch
Rear Rack
Viper 60" Plow
Moose Heated Grips
atv trailer modifications pictures
dump trailer to atv forums
hitching polar atv to lawn tractor
how do you fix rear hitch for a polaris atv
polaris 500 trailer cart hookup
powered by vbulletin dump trailer
put a hitch on the front of my atv
quad yard cart forums
what hitch do i put on my atv
finally fixed the overheating problem and AWD atvman2010 ATV Repair and Maintenance 0 06-26-2011 11:35 AM
Clicking not fixed! Desert Dog ATV Repair and Maintenance 10 05-16-2011 09:17 AM
ball joint "problem" fixed... denseleit Polaris XP 3 05-03-2011 05:48 PM
finally fixed the AWD!! atvman2010 ATV Repair and Maintenance 4 02-09-2011 05:35 PM
Please Help answer my ??? here i have to get it fixed today Heavy Sausage ATV General Discussion 0 11-14-2010 05:50 AM
