Old 10-03-2011, 01:00 PM
Kodiak's Avatar
Member #11963
400 2stroke carb on my 250 2stroke help.
I went and decided to replace my trailblazer 250 carb with my carb from my xplorer 400 with a blown engine. Anyway I used some gorilla tape and zip ties to mount the carb to engine since the opening was to small, and the air box is going to need some changes to make it work, so I just skipped the airbox and used a smaller airfilter. It started up but I could only start in gear or the it would grind trying to shift. It sounded pretty loud and actually seemed to run better than before, but the throttle would only move like 1/10 forward n then wouldn't push anymore without wiggling and pushing pressure on it. And when it finally went past that point the bike took off and wouldn't back off. Any idea on how to fix this would be greatly appreciate
-Hunter
Tags
carb, problem, swap, trailblazer
400 engine in polaris 250
atv 250cc 2stroke pictures gallery
carburator for poloris atv
how to fix my polaris carburetor
how to put a 2stroke 400 carb on 250
is the polaris 400l carb the same as the polaris 250 carb
pics of a 2 stroke polaris atv
pictures of polaris carb
polaris 400 2 stroke carberator help
polaris 400 2 stroke pics
polaris 400 carb for polaris trail blazer
polaris 400 carb on 250
polaris 400 carburetor on a 250
polaris trailblazer 250 carburetor
polaris trailboss 250 2 stroke carberators
polris carb swap trailblazer 250
trailblazer 250 400 carb
trailblazer 250 with 400 carb
trailblazer polaris carb swap
what carburator is used on a polaris 400 2 stroke
Parting out 1995 xploer 4x4 2stroke soon tt425 ATV Parts for Sale 139 07-21-2011 04:30 AM
400 2stroke snorkles? LH4X4 Polaris Sportsman 2 12-21-2010 01:31 PM
350L 2stroke port question KUNZROD ATV Repair and Maintenance 0 10-22-2010 03:12 PM
92 trailboss 250 2x4 2stroke benm ATV Repair and Maintenance 3 05-26-2010 07:41 PM
please help with Polaris Trailboss 250 2stroke.... ray.b ATV Repair and Maintenance 8 06-19-2009 06:16 PM
