Old 11-02-2011, 09:39 AM
goosemanx's Avatar
Member #9120
Power wire for hand warmers
I have a 06 450 sportsman,was installing hand and thumb warmers had power wire from hand warmers wired into yellow wire fromhigh beam headlight,but warmers would only work with light on.
where should i connect the power wire to so i have power at all times
thanks
Old 11-02-2011, 10:29 AM
the orange/white wire under the headlight pod that is not connected to anything. There are two seperate wires under there. Either is fine, they are both acc. power wires. Its a key on 12v power.
They wire you tied into is only live when the headlight is on as you found out.
Old 11-02-2011, 05:44 PM
goosemanx's Avatar
Member #9120
Thanks blueline15m thats exactly what i was looking for.
Old 11-24-2011, 03:33 PM
shep's Avatar
Member #20739
on my o11 550 i took my main power to my switch off the 12v "cig lighter" and then mounted my switch in the side of the head lamp modual down by where the handle bar comes out. power only comes on when the key is "on" so there is not worries of leaving your heaters on and draining the batt. with the key off. i can post pictures if need be.
Old 11-24-2011, 05:51 PM
Bjmcconk's Avatar
Member #18732
What is the red blue wire? I see the red white as key power but just wondering what that red blue wire is.
I am here: http://maps.google.com/maps?ll=43.661542,-84.238210
Old 12-05-2011, 02:39 AM
skidoodan's Avatar
Member #21098
I am getting ready to install mine. Looks like there is an orange wire, and 2 brown wires that go the the 12v "cig lighter" Which one is the power wire?
I also need to ground the handwarmers, where did you ground yours?
Old 12-05-2011, 04:19 AM
shep's Avatar
Member #20739
I'll open it up tonight and take a few pictures I dont exactly remember the colors
2011 sportsman 550 EFI
-heated grips
-polaris 2500# winch
-AcerBis uniko atv handguards
-moose 48" plow
Old 12-05-2011, 06:06 PM
shep's Avatar
Member #20739
the orange and white wire on the "cig" lighter is the power wire, i snipped the wire off as close to the OEM conector stripped it back and put it and my handwarmer power in a new spade connector
for the ground i put the two gronds in a connector with a round end on it and use a self tapping screw and ran it into the metal bracket inside the pod.
hope this helps
neal
-heated grips
-moose 48" plow
Old 12-07-2011, 08:30 AM
Natureboy's Avatar
Member #13820
Thanks for the pics Shep, just got some handwarmers.
2011 Sportsman 500 HO
KFI 3000# winch
Ricochet A Arm Armor
Rear Rack
Polaris Front Rack Extender
Viper 60" Plow
Moose Heated Grips
Old 12-07-2011, 08:51 AM
shep's Avatar
Member #20739
Ps The spade conectors I got are shealded from end to end as you and see on the power wire I noticed the oem one was too. Thought it was a good idea to use this style rather then the exposed ends incase water gets up in there or something
-heated grips
-moose 48" plow
12v hand warmer
atv hand warmer wiring 3 wires
atv heated grips installation
conecting thum warmers polaris quad
hand warmers power polaris sportsman
how to replace polaris handwarmer wires
how to wire hand warmers and thumb warmers
how to wire hand warmers for a polaris
polaris 500 ho what wire to tap into for heated grips
polaris atv hand warmers
polaris hand warmer wiring
polaris hand warmer wiring colors
polaris hand warmers
polaris hand warmers orange white wire
polaris handwarmer wiring
polaris sportsman hand warmers
sportsman 500 efi hand/thumb warmer installation
sportsman 500 where to get power for hand warmers
wire hand warmers
wiring hand warmers on polaris sportsman
hand warmers Carter66 ATV General Discussion 3 10-31-2011 04:28 PM
Polaris Hand & Thumb Warmers IndyRed800 ATV Visual & Body Modifications 8 10-31-2011 02:09 AM
hand warmers coolzzy Polaris Sportsman 8 05-26-2011 04:09 PM
Hand warmers 3 Polaris Atvs ATV Visual & Body Modifications 6 05-16-2011 03:40 PM
hand and thumb warmers? mkeddie ATV Performance Modifications 6 10-21-2010 07:43 PM
