12-07-2011, 04:17 PM
Member #20739
synthetic whinch cable input
i was talking with somt guys at work the other day and they said oh if your going to do alot of plowing get a synthetic "rope cable", each of them had broke their steal ones numerous times. on the other hand two of my good friends also plow there driveways and what not and i have never heard of them ever breaking there steal cable.
how many of your run synthetic? is this somthing i should worry about? are there any draw backs to the synthetic one? and is it as good as the steal one if im out in the woods and need to use it to pull myself or someone out?
thanks
neal
2011 sportsman 550 EFI
-heated grips
-polaris 2500# winch
-AcerBis uniko atv handguards
-moose 48" plow
12-07-2011, 04:44 PM
Member #10646
I have the synthetic rope on my winch.And im amazed how strong it is. i use my winch alot pulling logs out of bush,Plowing well worth it.!!!!
12-07-2011, 05:54 PM
Member #20739
Thank you, any brand better then another???
-heated grips
-moose 48" plow
12-08-2011, 01:30 PM
Member #20739
also has anyone ever had a problem with if freezing up? i coud see that thing soaking up water then freezing to its self.
thanks
neal
-heated grips
-moose 48" plow
12-11-2011, 12:02 AM
Member #10907
I plow with mine a lot and have never had a problem with water freezing it. Used to have a steel cable and I was always having to repair the eye cause it would kink and break all the time.
The synthetic is WAAAAYY better.
my .02
'05 Sportsman 500ho
Glacier plow, Synthetic winch rope.
We must reject the idea that every time a law's broken, society is guilty rather than the lawbreaker. It is time to restore the American precept that each individual is accountable for his actions. ~Ronald Reagan
12-11-2011, 04:46 AM
Member #6512
i use a synthetic rope also and on a glacier 2 plow system on my 850 the angle is a little sharp and have broken my rope alot whenever i hit something solid like a snowbank.
2010 Sportsman 850 XP EPS Stealth Black
Glacier II Plow System
3500 lb Polaris Winch w/ synthetic rope,Rubber Down Customs: Custom "GOT MUD" Aluminum Fairlead
2010 Sportsman 550 XP EPS Crimson Red, Rear Seat
12-11-2011, 08:29 AM
Member #19189
One hell ride in the mud using the winch about 10 times I kinked the steel cable in about 3 places and now the winch has some difficulties spooling. Im so done with steel cables!
You will want to puchase 50' Amsteel Blue Synthetic Rope and nothing less. 3 1/16" rope is more then enough for the 2500lbs winch and more then enough for even a 3500lbs winch.
As always make sure to purchase a new fairlead as your old one will be marked up from the steel cable. I also recommend a winch saver so you don't winch in the rope too far and mess up the fiarlead by dragging in the timble or hook.
I purchase a complete kit from this e-bay seller:
http://stores.ebay.ca/BLITZKRUEG-products-LLC
For me he had quality products and shipped to canada with decent rates via USPS. Be aware the cheaper e-bay sellers may sell you a zinc coated timble, or zince coated firalead hardware where this seller is all stainless steel. Just little things to watch.
Shawn
2011 Sportsman 800 EFI
Pure-Polaris 2500lbs Winch w/ 50' Amsteel Blue Synthetic Winch Rope, & UHMW Synthetic Roller Fairlead w/ Winch Saver
Pure-Polaris Lock & Ride Low Black Windshield
Pure-Polaris Lock & Ride Front Cargo Box
Pure-Polaris Glacier II Plow System w/ 52" Snow Blade
Pure-Polaris Sportsman Trailerable Cover
12-11-2011, 09:32 AM
Member #20739
thanks for the input, that seller is like 30-45 min from my house LOL
-heated grips
-moose 48" plow
12-11-2011, 01:37 PM
I agree with the guys so far. Syn line is actually stronger then cable!!! BUT you need to be careful of abrasion, dont run it over a sharp edge!
Personally I use a short piece for plowing, but I have never broken it. I think many people break the cable over lifting the plow.
New HAWES fairleed is excellent advice. If you have a roller you could get away with changing the rollers. I prefer a aluminum hawes fairleed for syn line. I have it on my Jeep and on my Sportsman NO ISSUES!!
12-12-2011, 01:57 PM
Member #20739
thanks CW, i was thinking the lead, but i also do alot of ice fishing in the winter and 50' of winch is a need be for emergencies.....
-heated grips
-moose 48" plow
how to install polaris synthetic cable on winch, polaris synthetic winch rope break, replacement winch fiarlead rollers, synthetic rope cable 1/16
