I removed one of screws (on each side) that go thru the lid and the alum tubing and used some longer 1/4 - 20 bolts and lock washers on the bolt head. It took a bit of work with the dremel on the base of the grip to get it to lay flat, just go slow so you don't take too much off. Sorry can't post a pic, will try to after I get a gopro for Christmas....
2012 Sportsman Touring 550 EPS
Polaris 2500lbs winch kit
KXP Ratcheting Rhino Grips
Reverse override switch
Wish List:
Cobra bush guards
Symtec heated grips and thumbwarmer
Rack extenders
