Old 12-26-2011, 07:18 AM
mudkicker's Avatar
Member #15075
Sportsman 550 gun boot mount
Just got a gun boot for my bike, I was wondering if someone could post a picture of what it looks like mounted up
The directions got thrown away lol
Thanks!
_______________________
2010 Sportsman 550 EFI
2005 Predator 500
Old 12-26-2011, 11:55 AM
greyguitar13's Avatar
Member #19431
Here's a picture of my 2011 Sportsman 800 with my Kolpin boot and bracket.
There are more than a few different models/styles of brackets out there so I'm not sure if this is the one you have or not.
This bracket must have been made for the pre 2010 Sportsmans because not all the holes in the bracket lined up with factory holes on the rear rack so I did have to drill new holes in the rack. What you can't see in the pics is that there is an included plate that sandwiches the rack and bolts through the bracket base. You can probably get away with less bolts than used, but I wasn't worried about it.
I did remove the rack for the install. I exchanged the included zinc plated hardware with stainless, as I do with all my atv accessories so I'm not dealing with rust. With this particular model, you can adjust the angle of the boot, which is nice. That way I can lean it up so its out of the way if I have someone riding on back (like in the picture) or you can lean it all the way forward, or all the way down to maximize cargo room on the rack if I have a deer loaded on. Normally there is a hex bolt, washer and nut that holds the preferred angle of the boot in place that needs to be tightened and loosened with hand tools. I went ahead and replaced that set up with a threaded knob so I can make the adjustment in the field without tools.
You may also notice that there is an eye bolt installed on the bracket base. Disregard that eyebolt, that isn't part of the set up. That's just my personal preferred method of attaching stuff to the rack. Anyhow, I hope this helps. Let me know if you would like anymore info or have questions on my set up-----Chris
Old 01-04-2012, 02:52 PM
mudkicker's Avatar
Member #15075
Wow it looks awsome
Did you get it from Polaris?
10 Sportsman 550EFI
05 Predator 500
Old 01-04-2012, 03:00 PM
mudkicker's Avatar
Member #15075
The story behind my deal is, I ordered it from my local Polaris dealer and they sent me the bracket for a Touring bike, which is way different. So I went today exchange it and they gavee the right one... Ill try to put it on tomorrow morning and I will let you know the out come
You bracket looks different from the one I picked up today, the one I have goes all the way to the floor board which I dont think is such a great idea.
10 Sportsman 550EFI
05 Predator 500
Old 01-04-2012, 07:14 PM
Member #19431
Got it off ebay. Its just the Kolpin Brand. I don't have any experience with the Polaris version, so I'm not sure of the pros and cons. Maybe you could review it for us when you get it installed
Old 01-05-2012, 12:46 PM
mudkicker's Avatar
Member #15075
I got it on late last nite
I didn't have to drill any hole at all or make any modifications but I won't lie, it had me confused for a while lol
You see, screws and bolts don't hold it down. It's a tension clap that when activated, it collapses inside the rack so tight it holds in place. And at the bottom is a small finger that slides it right into place
I will post pictures of it as soon as I figure out how to lol
The installation wasn't bad... Just not what I was waiting for... I was expecting alot more labor than what there was.
Had I have known how and where everything goes and fits I could have it all together and ready in a quick 10 minutes
__________________________
10 Sportsman 550
05 Predator 500
gun boot for 2011 polaris sportsman
gun boot for sportsman
gun boot for sportsman?
gun boot polaris sportsman 550 touring
gun boots for polaris 550
how to mount a kolpin gun boot on a polaris sportsman
how to put a gun boot and mount for polaris sportsmans
how to put a gun boot on a polaris 500
kolpin gun boot mount for 2011 polaris sportsman
mounting gun boot on polaris atv polaris gun boot bracket
pictures of polaris sportsman with gun boot
polaris 550 scabbard bracket
polaris gun boot
polaris gunboot mounts
sportsman rack holes
Sportsman 400 HO CV Boot replacement jnw ATV Repair and Maintenance 2 10-07-2011 12:18 PM
Carb intake boot for a 500 HO sportsman 2001sportsman400 ATV Parts for Sale 0 09-23-2011 03:24 PM
98 sportsman looking for rear boot covers aide Polaris Sportsman 2 04-26-2011 01:27 PM
300 Sportsman CV Boot Guards mackcat Polaris Sportsman 4 04-02-2011 07:05 AM
Sportsman 300 CV Boot protection ray14sher Polaris Sportsman 2 09-15-2009 06:40 AM
