  #11 (permalink)
Old 01-28-2012, 04:37 PM
SeanE1987's Avatar
Member #16252
We have Lincoln's at work, they're a bit big for home use, about the size of my Xplorer 300 and runs off 480volt 3-phase lol. Can weld 1/2" in a single pass
1998 Xplorer 300-Stock
  #12 (permalink)
Old 01-28-2012, 04:46 PM
jac42779's Avatar
Member #17976
Rack looks really good. Only a suggestion, you may want to put some rubber down where the fuel pack sits on the the metal. Not sure that it would wear a hole, but after a few rides should tell.
  #13 (permalink)
Old 01-28-2012, 05:26 PM
res2cue's Avatar
Member #15153
DONE! and thanks for the tip!
  #14 (permalink)
Old 01-28-2012, 07:31 PM
KICKER431's Avatar
Member #18006
Thanks for the advice guys. I have always wanted to learn but with other time commitments ( read 3 jobs, 2 kids, a wife, and always it seems at least one machine being fixed) I have never had the time to go to the class. maybe I will pick up a welder, read the manual, and get to practicing. Would love to hear what machines you fellas own/recommend.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
  #15 (permalink)
Old 01-29-2012, 09:09 AM
shui5612's Avatar
Member #19703
honestly, i got myself a 180 mig-pak from Lincoln Electric.
its WAY more than enough.
it can weld up to 1/2 without gas
K2659-1 MIG-Pak 180 208/230/1/60 (sold only in Canada) | Lincoln Electric
im sure there is a similar model for sale in the states, i just found that, this model is perfectly balanced for any application.
you can use with gas, 75%argon 25%CO2
or get another gauge for 100% CO2 (although its an "older" "design")
another option is the aluminum gun, to weld alum.
and you can weld stainless steel aswell.
you can also weld really thin metal, i believe 24 gauge, which is too thin for most of my welds/projects....
although this machine requires 240V, its still easy to set up yourself or hire an electrician to do it if you cant do it.
there are smaller machines, most notably the mig-pak 160(?) that can be hooked up to both 115V and 240V, which is a good choice as its dual current (portability)
smaller machines will surely do the job, but you are considering a long term purchase, so there was no "better" deal than the 180, as it welds really thin and thick metal.
(i probably will never need to weld 1/2" steel)
just be ready to spend some money on accessories, like a good helmet most notably, auto-darkening ones.
as far as brands go, for smaller machines (like the 180) Miller or Hobart are "better" but come at a much higher price, while Lincolns are more known for the bigger machines.
But IMHO the Lincoln does the job really well, alot of people i know had the machines for some time and i had mine for 2 years without any problems.
As far as courses/classes go, i never took one and weld pretty well, honestly, there is nothing better than 2 hours of practice, welding different metals (thickness wise) and so on.
Im sure there are cheaper brands that do the job and smaller models, but like i said, the 180 seems to be the "best" balanced.
Just wanted to add that i find some accessories to be a "MUST":
-good pair of gloves, and a good apron, good mask.
-dont forget some tools like a steel brush, a magnet, and some vise grips ( or any other tools that could hold objects together. ).
i find that gas is a must for most applications, find out where you can buy some, i get mine for 30$ a year for the tank, and 50$ a refill, a tank lasted me for many hours of welds, id say near 2 hours, which is allot, just to give you an idea,
it consisted of reinforcing/modifying 3 trailers, building shelves, and some other small projects,
IMG_0312.jpg picture by shui5612 - Photobucket you can see the winch platform welded by me to accommodate the larger winch, and the longer hitch, consisting of 2 bars each 2x3 and about 3.5MM thick, welded together and then welded to the trailer.
IMG_0308.jpg picture by shui5612 - Photobucket
IMG_0307.jpg picture by shui5612 - Photobucket really old trailler i have, welded the frame back together and added the rear hitch, 2x2 and 3.5mm thick metal.
IMG_0314.jpg picture by shui5612 - Photobucket one of the small projects i did, welded the frame so it fits into a car hitch (or the trailers) and i could use the crane, it isnt dont yet, those trailer jacks will be replaced by hydraulics as soon as i can make a hydraulic pump on my atv.
there were many other projects and such, but these are just to give you an idea...
and for my last point, i would suggest getting a MIG, stick welders are great and all, but for smaller projects, ease of use, learn-ability and functionality.
Hope i helped. sorry for the long post.
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
  #16 (permalink)
Old 01-29-2012, 02:59 PM
SkipStr's Avatar
Member #21899
I use a 115 volt Hobart Handler mig. It's a great home unit. Plugs into a household outlet and can be used with out gas. You can weld up to 3/16" material. It is a little pricey because it is a Hobart but well worth the investment.
FREE SHIPPING — Hobart Handler 125 115V Flux Cored/MIG-Ready Welder — 125 Amp Output , Model# 500495 | Wirefeed Welding | Northern Tool + Equipment
I would really recommend an auto-darkening helmet. I have always used a coventional helmet but being able to see where you are starting your weld will greatly shorten the learning curve. It is well worth the extra few dollars.
Skip
  #17 (permalink)
Old 01-30-2012, 11:53 AM
atv king's Avatar
Member #7031
^^x2 on the auto darkening hood way better then a normal one mine is one from northern tool and it was $200-$250 I'm not sure if they cost the same now as I've had mine for 4 years but it is a very nice hood.
2003 Sportsman 700
Windshield-Polaris Billet gas cap-Billet Shifter
Kolpin 3way hitch-Kolpin Fuel pack-Kolpin Rear Seat
Diamond plate boot guards-radiator cover-racks
2000lb winch-Custom front bumper with enough light to turn night into day!
Custom mounted rear winch
Polaris rear grab bar
Big Gun full exhaust, soon to be dual exhaust!!
Pure Polaris Black aluminum skids
Uni air filter
COMING SOON
28" ol2's skinny wide or 28" terms skinny wide
On 14" hd3 rims
  #18 (permalink)
Old 02-03-2012, 08:01 PM
Forrest's Avatar
Member #21911
Tag, never welded anything before, some good info here, have a trailer that might need some work.
  #19 (permalink)
Old 02-10-2012, 08:24 PM
Colorado_Mountains_850XP's Avatar
Member #22869
what would you recommend
Originally Posted by SeanE1987 View Post
Nice Job!!!, That looks really good
Sean,
I have an old ARC welder but for a home/hobby mig unit, what would you recommend? I don't want to break the bank, since I would rather spend my $$ on the ATV. Thanks, John
2011 850 XP
2,500 lb winch on a KFI mount
Warn ProVantage 60" blade on a center mount
and a wish list a mile long
  #20 (permalink)
Old 02-11-2012, 06:20 AM
macka's Avatar
Member #23019
I'd check out WeldingDepot -- Hobart Handler® 140 Mig 500500 110 Volt 140 Amp (No Gas or Gas) Mig Welder 5/3/1 Year Warranty personally I have used this helping out a buddy of mine. He picked his up off of CL for a song. I'd also look into a lincoln. craigslist and want ads are your friend. I'd buy a good helmet, either a chin flip type helmet or a good auto helmet. Your eyes are something you don't want to skimp on for safety.
2012 sportsman x2 2 hitch
can you weld on 550 polaris
how does atv eps work?
how does polaris eps work
polaris 850 xp front box hinges
polaris sportsman steel body
sportsman x2 modifications
brakes work great than they dont. then work agian thepopeis1 ATV Brakes & Suspension 1 08-07-2011 04:07 PM
What is e.t.c. How does it work gthpprteam ATV Repair and Maintenance 15 06-11-2011 11:20 PM
will this work???? slp_789 Polaris Sportsman 0 09-07-2010 08:54 PM
ADC - How does it work?? WilliamBos Polaris Sportsman 7 07-07-2010 06:47 PM
4x4 no work???? grider Polaris Scrambler 6 12-14-2009 11:26 AM
