Old 02-02-2012, 09:15 PM
POLARIS13's Avatar
Member #20347
Transmission problems
On my 07 700 efi, the spring pin started to fall out and made a grove in the tranny case....this caused the oil to leak out and water to get in and ruin all the bearings.
We took the case to a metal shop and had them aluminum weld it and bought all new bearings and seals to rebuild it.
Has anybody else had this problem!????
Old 02-02-2012, 10:29 PM
WOW!
Old 02-03-2012, 02:27 AM
res2cue's Avatar
Member #15153
Oh crap.
You never heard it grinding down the case?
Old 02-03-2012, 11:30 AM
POLARIS13's Avatar
Member #20347
yea...wasnt good. but nope, never heard a thing untill it started to whine/scream and wouldnt shift....so we started looking and it wasnt good!
Old 02-03-2012, 12:17 PM
lost cause's Avatar
Member #9763
Yes this is a known issue with the role pins backing out and causing this issue. I take the role pins out and replace with grade 8 bolts and loctite.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 02-03-2012, 01:57 PM
POLARIS13's Avatar
Member #20347
THis happens alot!? i havent seen anything on the forum of people having the same problem. but we got it back together and ready to go...ill see what my dad has to say about putting the bolt in...cause after all it is the "farms" wheeler....i have a 09 900 efi that i might do that to.
atv transmission problems
polaris atv drivetrain problems
polaris atv problems
polaris atv transmission backlash
polaris atv transmission problems
polaris atv transmission squeal
polaris transmission problems
transmission problems hasbeen10 ATV Repair and Maintenance 10 02-02-2012 09:40 PM
Will this cause transmission problems? Amccoy ATV General Discussion 5 08-29-2011 05:15 AM
Sportsman 400 transmission problems bcc22468@yahoo.com ATV Repair and Maintenance 2 05-29-2011 02:59 PM
91 trailboss transmission problems skijit ATV New Members 1 03-19-2011 06:39 AM
Transmission Problems trailboss4x4 ATV Repair and Maintenance 2 08-22-2010 06:35 PM
