Old 03-13-2010, 11:55 AM
Smoothbassman's Avatar
Member #2920
Brush Guard Lights Installed
Got my last upgrade done before the riding season. I installed some lights on my brushguard.
Polaris makes it super easy to install stuff on your quad as there are quite a few extra 12 volt sources tied up under the front panel.
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 03-13-2010, 12:03 PM
MUDDIE49's Avatar
Member #858
That looks pretty sweet......!!!Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
Old 03-13-2010, 02:54 PM
chopper89's Avatar
Member #1634
Cool
lookks awsome!!! and welcome back muddie havent seen you in awhile.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 03-13-2010, 04:19 PM
BRKCOP's Avatar
Member #2164
Real nice............
2009 Polaris 850XP EPS, Stealth Black, OGIO Bags, ATV GURU Bumpers, more to come. XPOG#0
Old 03-14-2010, 05:16 PM
PawPaw's Avatar
Member #962
Look's great, shine any deer yet?
Old 03-14-2010, 05:22 PM
looks awesome!
any plans to go to HID's on all 5 lights?
Old 03-14-2010, 05:24 PM
redneck2725's Avatar
Member #3177
Looks great, that would be really nice on some night time trail riding
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
Old 03-15-2010, 05:07 AM
Grunthunter's Avatar
Member #2758
How are the lights attached to your brush guard? Did you have to make some special brackets for them? Do you have any daytime close up photos of how they're mounted that you could post. I'd like to add some additional lights also.
Old 03-15-2010, 01:56 PM
Member #2920
There are mounting holes for lights on the front brush guard. I just ran the post of the lights through those holes and tightened it down with a lock nut and washer so it couldn't shake loose while I'm riding.
I wrapped the power leads with black friction tape, and pulled them wire leads thru the front grill and plugged into a quick connector right in front of the radiator so If I break a light or need a new set all I need to do is switch out the lights, and plug them in.
It was crazy easy to do, as there are two unused twelve volt sources under the front rack that you can tie into with no problems.
I Installed the switch on the headlight pod and stashed the relay and fuse in the headlight pod.
I honestly could have wired them into the same circuit as the main headlights, but wanted to be able to switch all the lights on and off independently plus I didn't want to draw too many amps on that circuit.
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 03-15-2010, 06:08 PM
Member #2758
NEAT ! Where are you guys finding those pan cake type lighted rocker switches? I'll have to check my brush guards as I didn't notice whether or not I had any holes in the for mounting lights.
2011 polaris front brush guard light install
atv brush guard lights
atv brush guards polaris lights
how to install front bumper litght harness on polaris sportsman
install polaris brush guard
installin polaris deluxe brush gaurd with lights
installing lights on brush guard
installing polaris atv lights
lights for polaris brush guard
lights for polaris sportsman brush guard
mount lights on polaris sportsman front brush guard
polaris atv brush guard
polaris atv brush guard lights
polaris atv brush guards
polaris brush guard light kit
polaris brush guard lights
polaris brushguard light kit
polaris brushguard lights
polaris rally lights
polaris sportsman brush guard lights
New ATV-GURU Bumpers Installed - Nice BRKCOP ATV Visual & Body Modifications 33 03-26-2011 06:16 PM
Winch and Bumper Guard Recomendation pondfishr ATV Performance Modifications 15 01-27-2011 07:03 PM
HID lights glamishustler Polaris Predator 1 12-02-2009 08:36 PM
hid lights johnyk39 ATV General Discussion 3 11-06-2009 08:36 PM
front brush guard & rear bumper ray14sher Polaris Sportsman 3 04-16-2009 06:43 PM
