Old 04-01-2010, 02:39 PM
Qman's Avatar
Member #3654
Liscence Plate Mounting - XP
Has any one mounted a liscence plate on the back of their XP? If so, can you post a pic or point me in the direction of one?
Thanks!
Old 04-01-2010, 08:09 PM
nmpolaris's Avatar
Member #3643
I did. I don't have a picture right now (It's 10PM) . But, I simply took my plate placed it where it looked right, on the muffler shield! Marked the 2 upper holes location on the shield with a sharpie. Carefully drilled 2 holes. Hold onto the drill good don't let the bit hit the muffler itself. Got 2 bolts and nuts with star washers attached. I believe the bolts were only about 1/2" or so in length. Don't use a bolt any longer than necessary. That was 3 weeks ago. Checked them the other day and they are still as tight as when put on. Good Luck.
Old 04-02-2010, 04:40 AM
slyder01's Avatar
Member #3440
There is an easier way without drilling, go to Lowe's or Home Depot and go to the electrical section and buy 2 conduit clamps, they have them with the rubber on as that will protect the paint, they will be a little small but they do work. Don't forget the necessary screws. Hope these pics will help ya
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
Old 04-02-2010, 09:07 AM
Qman's Avatar
Member #3654
Thanks guys - both great ideas!
Old 08-20-2011, 03:59 PM
guruerror's Avatar
Member #17443
Not an XP...but this might give you some ideas...I had to lose that third brake light.
...the chrome won't get you home.
CNTRY
Old 08-20-2011, 07:47 PM
twotxns's Avatar
Member #15865
Here is a picture of my plate mount on the 850XP. I did a fast and easy way of mounting mine and then I went to Pep Boys for some led lights and drilled holes into the plastic and recessed the lights and wired them into the tail lights.
Todd H.
2011 Sportsman 850 XP Touring - XP Deluxe front & rear bumpers, cheap driving lights, Polaris front & rear a arm guards, Viper 3k winch w/rope, XP Touring rear cargo box, Goodyear Rawhide MT/R's.
Old 08-20-2011, 07:50 PM
twotxns's Avatar
Member #15865
The touring model does not have a box in the rear, so this was an easy install. When I purchased the XP from the dealer, they had drilled holes in the alum. heat guard on the muffler. Unfortunately the wiring harness made it 4 miles before melting on the muffler. I might go back to the original plate mount on the heat shield, just depends on what ideas come into my head for lights...
Todd H.
Old 08-20-2011, 08:24 PM
crashnburn's Avatar
Member #12924
i just zap strapped mine to the rear frame where nothing can hit it.
Old 08-22-2011, 07:09 PM
Jach7's Avatar
Member #16667
agreed ^^ i just zip strapped mine to the grab handle on the back
Old 08-22-2011, 08:00 PM
twotxns's Avatar
Member #15865
Sorry, not legal in AZ if you are going to license it in the state. It also has to have a license plate light.
Todd H.
license plate on a 2011 sportsman 850 xp
polaris sportsman 850 xp wiring license plate light
where to mount license plate to 2011 polaris 850xp
were to mount the license plate any suggestions Odds-r-even Polaris Sportsman 26 04-09-2010 09:02 AM
08 Sportsman winch mounting HONDARACER Polaris Sportsman 7 03-26-2010 03:46 PM
plow mounting question rjgalano Polaris Sportsman 3 11-21-2009 05:21 PM
skid plate 2004 ???? dtsesthx ATV Visual & Body Modifications 0 11-13-2009 03:48 PM
2004 Plow Mounting Placement pasty64 Polaris Sportsman 1 09-15-2009 05:21 PM
