can cold weather deflate a tire? - Polaris ATV Forum
post #1 of 13 (permalink) Old 12-20-2010, 09:11 PM Thread Starter
Scott6by's Avatar
my left front tire is looking very low, and I'm wondering if cold weather can have an effect on low presure tires? I only did have 6 psi in them, and even at that they always did look a little flat.
and if I did run over a nail or ever do run over one. are inner tubes avalable for ATV tires?
Scott6by is offline
post #2 of 13 (permalink) Old 12-20-2010, 09:23 PM
glngib's Avatar
Send a message via AIM to glngib Send a message via Yahoo to glngib
Ha! I took a quick ride Sunday and was on a gravel road and noticed some sway and I thought it was the gravel. Well, I was playing around on a river beach and still noticed a soft sway conditioned. So, I glanced at the tires and yep, my left front tire looked low. I never checked them before I left. I did cross the river, so I thought maybe hit something there. Got home and it had about 2 - 3 lbs pressure. The other tires were just under 5 lbs. I just got my Sprortsman 400 about a month ago and it has been pretty cold.
Monday, I cleaned and examined the tire and didn't see anything and it appears to be holding up. Could even be the valve stem leaking? If it keeps on I will shoot some slime in it.
2014 Polaris Ranger 570
2011 Polaris Sportsman 400 HO
Polaris front storage compartment (like the 500's)
Polaris 2500 winch
Polaris deluxe brush guard front and rear
Mad Dog 3-way hitch (hitch pin hole interfers with trailer tongue)
Polaris Glacier III snow plow with a rubber wear blade
Polaris rear rack extender
glngib is offline
post #3 of 13 (permalink) Old 12-20-2010, 09:23 PM
cookies's Avatar
yes, temperature affects pressure.
yes, inner tubes are available for atv wheels.
i check my tire pressure at least once a week. Right now I am running 3-4psi in my tires. (gonna get some snow tonight)
cookies is offline
post #4 of 13 (permalink) Old 12-20-2010, 10:43 PM Thread Starter
Scott6by's Avatar
cool thanks.
I probably should check that more often then, my last ATV had high presure tires "32psi" so I never really had to check them.
Scott6by is offline
post #5 of 13 (permalink) Old 12-20-2010, 11:03 PM
cookies's Avatar
you want to make sure your pressure gauge reads accurately at low psi, many of the cheapie ones people toss in the glove box of their cars and trucks are not very accurate at all under 10psi. this is the one i have, it's one of the cheaper low pressure ones but it works fine for me.
http://www.amazon.com/Slime-20096-Pressure-Dial-Gauge/dp/B0020SYY3O
cookies is offline
post #6 of 13 (permalink) Old 12-20-2010, 11:05 PM
cookies's Avatar
also, what kind of atv tires run at 32psi? all the ones ive used you just inflate them that high to seal the bead, then bring down to around 6 or so. except the john deere gator, i think those may be around 26psi or so.... carsile 489's i think.
cookies is offline
post #7 of 13 (permalink) Old 12-21-2010, 04:55 AM Thread Starter
Scott6by's Avatar
I have a low presure guage, it came with the Magnums tool kit.
they may have been aftermarket tires or something. I don't have them anymore so I can't check, but they did say 32psi max on the side and they where very firm unlike the Magnums soft squishy tires and 6psi maximum. they where from a 1999 Arctic Cat 400 but i don't think they where stock.
Scott6by is offline
post #8 of 13 (permalink) Old 12-21-2010, 10:27 AM
glngib's Avatar
Well, just got back from Cabelas and bought the Slime low pressure gage and it won't even pick up a reading. The cheap gage the dealer gave me when I bought the machine reads 5lbs. I also checked it with a floor pump I have and it reads 5lbs. So, kind of dissappointed.
Polaris 2500 winch
glngib is offline
post #9 of 13 (permalink) Old 12-21-2010, 11:08 AM
cookies's Avatar
ouch, i'd take it back. mine does the opposite, reads when other gauges wont.
cookies is offline
post #10 of 13 (permalink) Old 12-21-2010, 11:16 AM
SNW629's Avatar
tire pressure can change up tp 1 psi for every 10 degree change in air temp. that is where the old saying comes from winter and summer air in your tires.
2010 850XP EPS,ITP XTR,DALTON CLUTCH KIT,WARN RT30,KFI MOUNT.HMF SWAMP XL.
SNW629 is offline
cold starting lucky1300 ATV Repair and Maintenance 2 12-18-2010 05:21 AM
Cold Air??? InkedAdrenaline ATV Performance Modifications 15 09-15-2010 03:08 PM
Suggestions on a great place to live with warm weather & ATVing Thor ATV General Discussion 26 08-25-2010 05:42 AM
Cold In Michigan buster634 ATV New Members 2 01-29-2010 11:55 AM
Cold weather starts Birdfish ATV New Members 4 01-08-2010 07:43 AM
