Tire Pressure question - Polaris ATV Forum
Old 12-09-2016, 10:17 AM
CoachCMak's Avatar
Member #95457
Since I'm new to ATVs, I'll ask the question here ... I was given some advice couple days ago (from a guy I do trust), he said he inflates his front tires to 10 psi. He says it steers like a breeze and it's easier on the plow. I understand all the "manufacture's recommendations" stuff, but my question is, is this common? Do guys do this, and if so, does it run the risk of messing with the front suspension?
Thanks for helping a newbie!
Live life, you only get one.
2004 Sportsman 500 H.O. 4x4 (6,100+ miles)
Carlisle AT489 25x8-12 fronts
Carlisle AT489 25x11-12 rears
Warn 2,500 Winch w/Moose synthetic winch rope
Old 12-09-2016, 11:01 AM
jgue498's Avatar
Member #39199
Well then you know 5-7 is the 'usual' folks use for 'most' situations. Yeah a little higher might help slow speed steering like when plowing so in That situation is makes sense to increase to 10 or so. If traveling fast down a bumpy road 10 would probably not be the best choice, make sense?
I'd say as your friend intends to use the quad at 10psi would not cause excess suspension wear, higher road speeds perhaps. Luck and enjoy.
1998 Sportsman 500 - 4725 miles
Front/Rear 18W-4 inch solid metal CREE LED Floods
Polaris 8" Rear Rack Extender
ODI Rogue 130mm grips
12.5" Kenda BearClaws on rears
2010 Sportsman 500 HO - 1362 miles 182hrs
Tamarack 10" Footpegs
Polaris Front brush guard - bumper
Wants BearClaw HTRs for Christmas!
Old 12-09-2016, 12:13 PM
bobx2's Avatar
Premium Member Premium Member
Member #14376
It's not something I do when I plow. I can see how it would steer a little easier, but, that usually isn't a problem when you are in the snow. It will also cost you some traction on the front end. It won't hurt anything running 10 psi, but I wouldn't bother. I run 5 psi max in the front and around 4 psi in the rear.
Old 12-19-2016, 05:20 PM
CoachCMak's Avatar
Member #95457
Well, here's an update ... I tried the 10 psi idea in both front tires. The only thing I noticed I didn't like was the loss of traction when I tried to steer while pushing a blade full of snow. I guess lesson learned. That's what I love about ATVing so far, trying to figure all this new stuff out. Thanks for the advice guys!
Old 12-20-2016, 04:40 PM
Diesel man 03's Avatar
Member #7294
Agree with bobx2.
Tire and Rim size question Slk1919 ATV Wheels & Tires 8 11-29-2016 09:11 AM
DIY Tire Changing BeadBuster ATV Wheels & Tires 1 11-28-2016 05:04 PM
Tire pressure for rock crawling Ghostjumper ATV Wheels & Tires 3 07-14-2016 01:38 PM
Tire pressure rj42584 ATV General Discussion 12 04-04-2016 12:00 PM
Front tire pressure with plow asbuilt Polaris XP 20 12-22-2015 11:57 AM
