Recommended tire slime/ sealant - Polaris ATV Forum
post #1 of 6 (permalink) Old 12-26-2016, 12:27 PM Thread Starter
abishoff's Avatar
So I went out on my first trail ride in the used 04 Sportsman 400. I quickly learned there aren't enough plugs for the thorns on the trails. I've been an avid mountain bike rider for a few years and use a slime/sealant in my tubeless setup on the bike and never have flats. What's the recommended tire slime/sealant for ATVs? I know Walmart carries a big pumper full of the "Slime" brand but I'm not sure if that's the way to go. What do y'all use?
abishoff is offline
post #2 of 6 (permalink) Old 12-26-2016, 01:47 PM
stave7119's Avatar
You don't say what tires you have so I am assuming that you have the stock 3 ply tires. I have used tire sealant in 3 wheeler tires with mixed results. It did seal the current leaks, but the next time I went into the bean field with the machine, I had problems again. I have also seen the results when you take the tire off the rim....not pretty
I would suggest better tires if you can swing it. I have 6 ply and 8 ply on my machines just for that reason. Even the Mud Lites on my 325 have stood up to the abuse. Maybe just newer tires. If there are any dry cracks on your tires, even a sealant isn't gonna hold up very well. Over time, the tire material dries out and gets brittle for lack of a better term. Or if the tread is worn out it could make a difference
1st Machine
2001 Magnum 325 with a blown engine; rebuilt 2004. Broke timeing chain 2016 rebuilt again and still running. Warn winch and Moose 60" plow
Wife's machine:
2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. 12x7 front, 12x8 rear, QSC Clutch Kit
My Trail Machine:
2004 Sportsman 600 Twin, 25" RipSaw Tires on stock steel wheels, Moose rear box
Completed Project machine:
2001 Magnum 325 MOSE with a blown engine. Transplanted a 2005 Magnum 330 engine. Committed suicide on the trail Oct 2016. Spun Rod Bearing after oild cooler line failure. Rebuilding Engine.
stave7119 is offline
post #3 of 6 (permalink) Old 12-26-2016, 01:51 PM Thread Starter
abishoff's Avatar
I'm not sure if they are stock tires, probably so. By that is a good point, getting a thicker ply tire would go a long way.
abishoff is offline
post #4 of 6 (permalink) Old 12-26-2016, 04:27 PM
bp405's Avatar
Like stated above get some 6-ply+ tires and then if the issue persists add a quality sealant like ultra-seal or Highlifter or quadboss.
2011 sportsman 800 efi
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
bp405 is offline
post #5 of 6 (permalink) Old 12-27-2016, 10:30 AM
ThorsHammer's Avatar
Do everything you can to avoid having to use those sealants. If you ever have to get into the tire again it's a nightmare. But at least you're looking to use it for the right purpose. Just remember, you'll still need plugs in case there is a sidewall issue. or a larger hole than the sealant can handle.
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Tamarack Titan Luxury Lounger
Cabela's Chainsaw mount
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
Towable/equipment
Custom built road drag grader
Future mods
Rear bumper/brush guard
ThorsHammer is offline
post #6 of 6 (permalink) Old 12-27-2016, 11:19 AM
x omerta x's Avatar
Highlifter sealant works well. Have used in in a few sets over the years and also washes always with water if you need to swap anything
x omerta x is offline
DIY Tire Changing BeadBuster ATV Wheels & Tires 1 11-28-2016 04:04 PM
Aftermarket Wheel / Tire Setup 850scram Polaris Scrambler XP 6 09-26-2016 08:18 AM
Larger tire size for Polaris 2006 450 help Newman0912 ATV Wheels & Tires 2 05-05-2016 03:00 PM
Haul Vehicle: Save $25.00 PER Tire on select Goodyear tires | Discount Tire Direct Discount Tire Discount Tire 2 03-15-2016 02:24 PM
Tire weight and size vs acceleration/power loss. Robooo ATV General Discussion 21 12-17-2015 01:44 PM
