New take-offs on my old Sportsman - Polaris ATV Forum
post #1 of 10 (permalink) Old 12-27-2016, 10:31 AM Thread Starter
abishoff's Avatar
I'm looking at some new take-off wheels and tire packages on Craigslist. Is there anything I need to consider when choosing what take-offs to get? There are a lot of good deals for ATV and utv take-offs that are the same tire size I have but I'm but sure if the rims are the same offset. I have a 2004 Sportsman 400.
abishoff is offline
post #2 of 10 (permalink) Old 12-27-2016, 10:41 AM
Lollygagger77's Avatar
What do you have? XP rims are most likely the only ones that wont fit much due to their offset.. And if you have an XP you will need a 14" rim and if you get anything different than stock offset you will most likely end up with a wide machine.
NEW ADDITION: 2016 RZR 900S w/EPS
2012 Polaris 850 XP HO w/EPS
-28" Terminators
-HD Springs and JCCAPRI bushings
-QSC Clutch kit
-3500# Polaris winch with Synthetic Rope
-Polaris Front Brush Guard
-Polaris Lock n Ride front and rear storage
-Polaris Mid Lock n Ride Windshield (smoke)
-60" Warn ProVantage Plow
-Symtec Hand Warmers
-Quadrax Rear seat w/foot rest kit from ATVSUPERSTORE - Square Tube
Old Machines:
2006 Sportsman 800 EFI, 2005 Sportsman 700 Carb, 2004 Sportsman 500HO Carb, 2000 Sportsman 500 Carb
Lollygagger77 is offline
post #3 of 10 (permalink) Old 12-27-2016, 10:57 AM Thread Starter
abishoff's Avatar
I have a 2004 Sportsman 400. I was looking at some Ranger take-offs
abishoff is offline
post #4 of 10 (permalink) Old 12-27-2016, 11:48 AM Thread Starter
abishoff's Avatar
Will these fit on my 2004 Sportsman 400 http://stlouis.craigslist.org/snw/5863382417.html
abishoff is offline
post #5 of 10 (permalink) Old 12-27-2016, 01:21 PM
craiglist is blocked at my work, but you should be fine with Ranger take offs...
-28" Terminators
-QSC Clutch kit
Old Machines:
post #6 of 10 (permalink) Old 12-27-2016, 03:00 PM
cariboo's Avatar
if you like to go with 9'' width in front you need 4+3 rims or spacers
otherwise the tires will most likely rub
cariboo is offline
post #7 of 10 (permalink) Old 01-04-2017, 07:24 AM Thread Starter
abishoff's Avatar
What is a 4+3 rim? I don't understand ATV wheel sizes yet? Do you recommend a wheel spacer? Are there any risks with running a wheel spacer?
abishoff is offline
post #8 of 10 (permalink) Old 01-04-2017, 06:30 PM
Vandal's Avatar
A 4+3 wheel is a wheel that has a 4+3 offset. The 4+3 offset wheels will position your tires a little farther out from the hub and give you more clearance. The 9 inch wide tire on the standard front wheel will likely hit the tie rod end so in order to us a 9 inch wide tire up front you'd either need to flip the tie rod ends or use a wheel such as the 4+3 offset wheel that we discussed, or wheel spacers
2016 570 RZR EPS Trail with EBS and Turf mode
Sunset Red
F+R windshields
Quadboss roof
Polaris Rear Cargo box
26X9X12 Maxxis Ceros
26X11X12 Maxxis Ceros
ITP SS 212 Machined wheels
UTV Giant V2 doors
Led Cubes
Polaris Low Profile front and rear brushguards
Badlands 3500# winch with moto-alliance winch mount
Highlifter 2 inch lift kit
Departed friends
2001 Kawasaki Bayou 300 4x4, a great 3 wheel drive ATV
2013 Sportsman 500 HO another great atv
2015 Polaris Ace 570....Problem free and too much fun
Vandal is offline
post #9 of 10 (permalink) Old 01-05-2017, 01:34 AM
phil's Avatar
Offset -
4+3
First number, 4, is the distance, in inches) from the wheel bolt face to the inside rim edge.
Second number, 3, is the distance from the wheel boltface to the outside rim edge.
If you go from from 6+1 to a 4+3, you will move the wheel (and tire) outward by 2 inches.
Some folks have an issue with overall width. In this case, if your machine is 48" wide with the standard setup and you swap wheels, you will be 52" wide. Make sure that it will fit where you want it to go.
3500 lb. Polaris HD Winch
VIPair Windshield
EPI HD Springs, Front & Rear
Cecco Frame Braces
Guru Bumpers, Front & Rear
Rhino Monster, Rear Box
Lowrance BAJA 540 GPS
SuperATV EZSteer 380
Various Mods for Ice-Fishing
phil is offline
post #10 of 10 (permalink) Old 01-05-2017, 06:41 AM
bobx2's Avatar
This will explain and illustrate wheels and offsets.
Ask the Professor
bobx2 is offline
Service manuals cookies ATV Repair and Maintenance 981 04-23-2017 11:10 AM
