14" rzr rims on sportsman 850sp - Polaris ATV Forum
Old 12-30-2016, 01:11 PM
Liftedpsd's Avatar
Member #55713
I found a good deal on 14" rzr rims pictured below for 60 bucks for all 4. Just making sure they will fit and seeing if the offset will make the atv wider? Here is a picture of them.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Old 12-30-2016, 03:57 PM
rm25x's Avatar
Member #60714
They are a direct replacement. I had them on my 850 before putting them on my scrambler. Same offset as the factory wheels.
2015 Scrambler 1000 XP
- Maxxis Bighorn 2.0's on RZR Turbo wheels
- Polaris 2500 lb winch
- Polaris Ogio rear storage bag
- RAM X-Mount for GPS duties
- Polaris Heated Grips & Thumb Warmer
- Polaris White/ Black Handguards
- Quadboss Pile Driver 60" Plow
Old 12-30-2016, 03:58 PM
Liftedpsd's Avatar
Member #55713
The offset was the same?
Old 12-30-2016, 04:04 PM
rm25x's Avatar
Member #60714
Yup. Fit exactly the same as the stock sportsman wheels.
Old 12-30-2016, 04:05 PM
Liftedpsd's Avatar
Member #55713
Ok thanks I'll still get them because 60 I think is a decent deal but wanted an inch wider to put my tires out a little more. But they will work.
Old 01-04-2017, 08:45 AM
abishoff's Avatar
Member #96810
Can't you just put a tire on that's a little wider?
Old 01-04-2017, 08:46 AM
Liftedpsd's Avatar
Member #55713
The tires I have on it rub and getting them out an inch will stop them from rubbing.
Old 01-04-2017, 08:48 AM
abishoff's Avatar
Member #96810
Ok so you want the offset to move the rim out?
Old 01-04-2017, 08:49 AM
Liftedpsd's Avatar
Member #55713
Yea and I'm hoping the rzr rims have just a little offset. My highlifter springs on the next to stiffest setting seem to pretty much stopped all the rubbing it only rubbed one riding last week. But still want a little offset and figured for 60 bucks I'll try them out.
Old 01-04-2017, 10:40 AM
sportsmandan's Avatar
Member #38721
worse case ill buy them off you for $65 for the wife's 570 (:
Service manuals cookies ATV Repair and Maintenance 969 01-06-2017 06:48 PM
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 1 11-21-2016 03:09 AM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 0 11-19-2016 04:12 AM
will 2016 14" sp rims fit on a base model sportsman? huggytree Polaris Sportsman 570 5 05-23-2016 08:32 AM
Softer rear shocks/springs? Unitoo1 Polaris Sportsman 10 04-25-2016 05:20 AM
