I have a 2017 sportsman 570, I want to use 30x8x12 interforce tires on the stock rims , are the back rims narrow enough for the 8 inch wide tire ? And has anyone run this size on their stock rims no lift ?
If you get them bead sealed during install you should be ok, otherwise you run the chance of them popping off the bead.
No idea if 30s clear a 570, maybe someone else will jump in.
27 will rub rear fenders if you have a load back there, so I'm kind of doubting 30s will fit without moderate rubbing
113.2K members
