07-26-2011, 03:06 PM
Member #2655
Bighorns on 09 850xp
Hey guys just curious if i can fit a set of big horns on my 09 850xp without any modifications or aftermarket rims any feedback would be appreciated
thanks in advance
tom
Hey Ya'll watch this- if i say this i'm getting Stuck.
2004 Ford F350 Lariat 4x4 6.0 Litre FX4
2004 Ford Ranger 4.0ltr 4x4 5spd
2009 Polaris sportsman 850xp
07-26-2011, 03:13 PM
That depends on what size you buy!
Sure you know that, so post up the size your considering!
07-26-2011, 03:16 PM
Member #2655
26x9x14F 26x11x14R
07-26-2011, 04:40 PM
Member #1414
no they will not fit the rear because of the sway bar on the 09. you can bend the bar,buy the 2010 bar,buy 1" spacers,buy aftermarket wheels.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
07-26-2011, 05:54 PM
Member #962
Yep, 1" spacer's in the rear should get the tires to clear the swaybar and that's if they rub. I had to use spacer's to clear my XTR's in the rear.
07-26-2011, 06:12 PM
Member #2655
I was also looking at gbc dirt comanders same size
Sent from my PC36100 using Tapatalk
07-26-2011, 06:59 PM
Member #14212
I've been really impressed with the Dirt Commanders.
Action
2011 850 XP EPS Camo
A Arm Guards F&R
F&R Storage box
GBC Dirt Commanders
ATV Guru Brush Guard F&R
Ricochet Skid Plates
UNI Air Filter
07-26-2011, 07:48 PM
Member #2655
Did you need spacers action
07-27-2011, 03:19 AM
Member #1414
tom look at action sig,he has a 2011,only the 09 needs a sway bar mod. i had a set of horns for my 09,they do not fit.almost all 11" do not.the only 11" that i have ever heard of that will is the zilla. i had them to so yes i know first hand they work. you will need to do one of the 4 mods i said.
09 850XP EPS
07-27-2011, 03:58 AM
I too like the looks of the Dirt Commanders. BUT for me trail riding is first priority and the DCs are not a radial. I chose the BHs and so far have been thrilled with the performance.
To my mind there are three choices for the best tire for 90% of the riders reading this and two overlap allot! That is the GBC Sparticus and Grim Reaper and the Maxxis Big Horn tires.
For more mud look to Sparticus for more rock the BH and GR. The GR has two more plies but is newer. Newer in its becoming proven. The BH is proven, its hands down THE tire ALL other tires in this field are measured against. Thats for trail and rocks.
09 850xp mods, 09 polaris 850 forum, 2009 polaris 850 xp eps camo pricing, 2009 polaris sportsman 850xp gbc dirt commanders, 27 bighorns on 850xp, 850 xp aftermarket rims, atv horns polaris, big horn fit on 850 xp, biggest tires sportsman 850 xp, polaris 850 eps big horns, polaris 850 with big horns, polaris 850 xp aftermarket tires, polaris 850 xp eps mods, polaris 850 xp with bighorn tire review, polaris 850 xp with bighorns, polaris 850xp atv handguards, polaris sportsman clutch kit with bighorns, sportsman 850 xp tires forum, whats the biggest tire you can fit on a sportsman 850 xp factory, which atv tire is best for 850 xp big
