Old 07-28-2011, 12:25 PM
MudLife500's Avatar
Member #13989
Question 2011 SP 500 - lift,tire,rim ?
I have a 2011 sportsman 500 ho..im looking to get some mud tires, zilla is what i think ill end up with. I was wondering how big should i go on a 500? i was wanting to put a 2" lift on it and maybe 28" zillas? im probly keeping the stock wheels for now unless i come across a deal.. ideas and opinions on the lift, tires, or rims would be appreciated. Thanks!
Old 07-28-2011, 02:40 PM
6.2's Avatar
6.2 6.2 is offline
Member #17136
How are you liking your quad? I'm looking at the same one. Any little quirks it has?
-Posted with my iPhone.
Old 07-28-2011, 02:54 PM
SMP63's Avatar
Member #13545
If you go with the 28's be ready to put a clutch in it!!!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 07-29-2011, 05:34 AM
MudLife500's Avatar
Member #13989
6.2 - I love it man. The ride, the way it handles, the pick up..just about everything. Honestly the only thing that sucks is that theres not alot of aftermarket parts for the 2011 yet. Obviously this will change, and it has nothing to do with the bike, just saying haha
SMP63 - Yea i was looking at epi the other day.. the only reason i say 28"s is because the zillas supposedly run small. But i do like the fact the zillas are so light, so its not tooo much strain and loss of power.
Old 07-30-2011, 11:46 AM
lost cause's Avatar
Member #9763
You can run 28's with no lift. If you are only planning on running 28 zillas you will need to do nothing. those tires are not that aggressive or heavy so you will be able to turn them fine without clutching or lift. only issue with the larger tires and lifts with these 2011's is the weak axles. I believe there is an issue with the axles binding up with a lift and you need to replace the axle bars with shorter one's from highlifter so they do not bind up. Make sure you use low gear if in water or mud or you will burn up the belt.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 08-23-2011, 11:18 AM
MudLife500's Avatar
Member #13989
yea i was reading up on that axle binding problem..does a 28" zilla really run an inch small? i dont want to get 27"s and them size up to 26"s..
Old 08-23-2011, 05:39 PM
muddin's Avatar
Member #17882
The stock rear axles won't work with a 2" lift . I have a 800 sportsman and broke the stock rear axles with in a month. I replaced all of the with gorilla axles when I did the 2" lift.
Old 08-26-2011, 09:16 PM
SledRacer112's Avatar
Member #11177
Sorry to bump older thread...but stock axles won't live with a 2 inch lift? I have been reading and though people were saying 2 inch lift and 2 inches bigger on tire would be ok for stock axles? I'm not planning to do a lift but a friend of mine is..
Sent via Tapatalk
Mine - 2007 Sportsman 800 - 27" Mudlites on SS rims, HID's, 3 headlight mod w/ relay, 2500lb winch, 4 gal rotopax, PowerMadd hand guards
Wife's - 2010 Polaris Sportsman 500 HO - HID's, 3 headlight mod w/relay and 2500lb winch, WES rear seat & kimpex foot pegs, 4 gal rotopax
Old 08-27-2011, 11:30 AM
polarisgodaddy's Avatar
Member #18069
28" Super Swamper Vampires for sale
New to the forum and Polaris, and I have a set of 28" Super Swamper Vampires (not what I need for the riding I will be doing). How do I get the word out locally that they are for sale? I m in West Ga
Old 08-27-2011, 05:37 PM
racer37l's Avatar
Member #5629
Welcome polarisgodaddy!
Try Craigslist, etc.
Con
10 inch wide tire polaris 500
10 inch wide tires on polaris 500 ho
2 lift 2011 sportsman 500
2011 polaris 500 tires and rims
2011 sportsman 500 28 tires
2011 sportsman 500 ho rim size
2011 sportsman 500 stock front rims new tires
27 inch tires 2011 500 ho
27 inch tires on sportsman 500
30 tires 2 inch lift polaris 500
green wheels for polaris 500
polaris 500 on 28's
polaris 500 sportsman 2 inch lift on 28s
polaris sportsman 500 rim size
rims that fit 2011 sportsman 500
sp500 rim
sportsman 500 2011 lift
sportsman 500 mud tires and rims
sportsman500 run 27 inch zillas
stock rims on 2011 sportsman 500
Tires and lift on 2011 Sportsman 500 HO jazlee88 Polaris Sportsman 26 04-30-2012 05:27 PM
New 3" lift on my 2011 550 xp wishiwasfishin Polaris XP 7 08-18-2011 01:53 PM
How much tire for the Lift?? mikmazz ATV New Members 10 07-21-2011 06:51 AM
do i need a lift and spacers to make 27 inch tires fit on stock 2011 sportsman 500? solid_crimson ATV Wheels & Tires 2 03-24-2011 05:56 AM
whats size tire and how much lift? maboree ATV General Discussion 16 12-16-2010 10:07 AM
