The wheels will be the problem. From what I've read, the XP wheels have a different offset than the regular Sportsman. If I remember correctly, you may have to use wheel spacers.
Also, the lug studs and lug nuts have a different pitch on their threads. You may have to get new lug studs and lug nuts.
I would advise you to see if you could try the wheels on your bike before you do the deal.
Good luck and if you get them, we need pics! lol
Con
