08-09-2011, 07:05 AM
Member #11166
sportsman xp 4+3 offset wheel width?
I was looking at a set raceline wheels for my xp with a 4+3 offset and I was wondering how wide this would make me with stock tires.
08-10-2011, 08:36 AM
Anyone with the 4+3 fronts here that can help Chad1926?
08-10-2011, 11:44 AM
I just checked with my distributor for you. It will be about 2 inches wider on each side.
08-10-2011, 12:25 PM
Member #11166
Is their any aftermarket wheel out their with factory offset?
08-10-2011, 01:01 PM
Member #5629
None I am aware of, but if you didn't want it that wide you might consider stock wheels with 1" or less spacers.
Con
08-10-2011, 01:53 PM
I just ordered wheels for testing on our 850XP that are supposed to keep her right at 50". Hope they will be better then the ITP's i tested last year. What a mud shower they gave me! I will post results when they arrive.
08-10-2011, 02:04 PM
Member #11166
Thanks thor hope they work!
09 sportsman xp 850 wheel offset, 4 3 offset atv, 4 3 offset will clear polaris, atv wheel width, off set polaris xp 850, polaris sixr rim offset, polaris sportsman 800 aftermarket wheel offset, polaris wheels stock width, polaris xp wheel offset, sportsman 850 xp rear tow hitch dimensions, sportsman 850 xp wheel offset, sportsman 850 xp wheels, stock offset polaris 500 wheels, thor avatar, what is sportsman 850 wheel off set, what rim offset for sportsman xp, what width is 4 3 offset, wheel offset for sportsman xp, wheel spacing for sportsman 850, wider wheel offset xp 850
