Old 09-03-2011, 06:27 PM
2010sportsman500's Avatar
Member #17820
2" Wider Tires
Hi, I have a 2010 Sportsman 500 ho. I am looking at buyying new tires for my av. If I put two inch wider tires on the front and rear, am I going to need to buy spacers? I think I will be okay in the back but I am not sure about the front. I really don't want my tires to rub on the suspesion or any thing else.
Old 09-03-2011, 06:33 PM
cwlongshot's Avatar
In a word, YES.
10's up front WILL need spacers. 12's out back likely the same depending on make of tire.
Old 09-03-2011, 11:21 PM
Member #17820
If I was to go with one inch wider tires all around would I still need spacers?
Old 09-10-2011, 06:30 PM
Member #17820
If i was to buy 28/9/12 zillas for the front and 28/11/12 for the back would I have to get spacers?
Old 09-11-2011, 01:03 AM
cwlongshot's Avatar
Wink
Maybe and maybe not. It depends on the tire itself. (Some have side lugs making them wider thru the tread than the carcass.)
Again assuming your keeping them mounted to stock rims...
Old 09-11-2011, 04:47 PM
Member #17820
ok thanks
Old 09-11-2011, 05:10 PM
bgirard420's Avatar
Member #11494
Cw is spot on, here's my 25x8x12 spartacus in the front. Not much clearance from the TRE's. I imagine if I got the 9's I'd be needing some spacers let alone 10's Some tires run more true to size than others. Rears don't tend to be a problem until greater than 12's on the 500's from what I've read.
So as far as the zilla's, if you stay on stock rims you'll probably need some spacers in the front (it'll be close) but the rears will be fine.
2010 Sportsman 500 H.O.
03 polaris 500 12 12 front back tires
03 polaris 500 27 12 front back tires
10 inch wide tire polaris 500
10 inch wide tires on polaris 500 ho
10 wide tire front what spacer inch 2011 polaris sportsman 500
2 inch wider tires on atv
20 inch tires polaris 325
atv wider tires on front
bigger tires on a 2011 polaris 500 ho
biggest tires on polaris 500 ho
going with wider tires on atv
if i put 10 inch wide tires on the front of my polaris sportsman would i need wheel spacers?
polaris wider tires
polaris with 10inch wide itres
quads with tank back tires
rear atv 10 vs 12
spacer size for 10 wide tire front polaris sportsman 500
wider tire on polaris
wider tires for atv
widers polaris
14" tires for sale mshump ATV Wheels & Tires 2 12-23-2011 08:19 AM
6" Lift, 30" Tires - PROBLEMS??? Hunt@r07 Polaris Sportsman 1 05-19-2011 05:11 AM
10 vs 12" rear tires?? kool_500HO ATV Wheels & Tires 1 02-20-2011 06:18 PM
26" Tires on stock 2011 500 HO kool_500HO ATV Wheels & Tires 8 02-20-2011 05:39 AM
How much Wider??? Breakineven ATV Wheels & Tires 6 08-06-2010 04:08 PM
