Old 09-08-2011, 04:16 PM
Trailblazersonny's Avatar
Member #13864
Cut a front tire. Can I do this?
Hey guys, I cut a front tire the other day on my 550XP. It has the stock Terrathons on it. I want to go to Big Horns. My question is this. Can I change out the front tires to Big Horns now and replace the rears later. I read the Big Horns are actually taller by 1/2 in than rated.(26 are 26 1/2) Will this pose a problem in 4WD. Thanks in advance.
TBS
2009 Sportsman 550 XP EPS
Polaris Lock n Ride Hard Case
Rotopax Fuel Tank
ATV Guru Front Brush Guard
Old 09-08-2011, 04:25 PM
hemisphere2's Avatar
Member #17561
I really don't think a 1/2'' will make a big difference when in 4x4 in the mud, but could pose a threat on hard packed surface in 4x4, or to be safe just keep it 2 wheel drive until you get the rears on.
2011 850XP camo
guru cobra front/rear bumpers
ricochet a arm guards
front cargo box
sti c7 wheels
26'' black diamond tires
3500# winch......coming soon
full ricochet skid plate......coming soon
power commander v.......coming soon
Old 09-08-2011, 04:40 PM
cwlongshot's Avatar
In a car its very dangerous to mix a radial with a bias ply tire.... Are the stockers bias plys? I know the BHs ARE radials.
Old 09-09-2011, 03:23 AM
Member #13864
I did not even think of that Longshot.. Not sure if it would make a difference at the slow speeds we travel. Something to think about. Thanks Hemi for your input. If I do mix I will make sure it is for a very short time.
TBS
Rotopax Fuel Tank
Old 09-09-2011, 06:19 PM
bigpete's Avatar
Member #13629
Shouldn't make a difference in 4x4 because the front wheels actually spin slower then the rears. There are some youtube videos showing this. As far as radial vs. bias at the speeds that we travel wont be to bad. Even if you do get up to 65 or 70 its only for a short time.
2010 850XP LE
Crimson Red
Looney Tuned Slip-on
M12 Diesels
26" MotoGrips
Highlifter Springs up front
Snork'd
3500# Viper Elite
Polaris Front and Rear Extreme Bumpers
Old 09-10-2011, 04:56 AM
Member #13864
Thanks Bigpete. Good info...
Rotopax Fuel Tank
atv tire cut repair
atv tire repair tread with cut
can i repair a cut in atv tire
cut atv tires
cut stock atv tires
fixing a cut in atv tire
how can you fix a big cut in a tire?
how to fix a sliced atv tire
how to fix big cut in atv tire
how to repair a cut in atv tires
how to repair a cut in the top of an atv tire
polaris atv hard case
repair a cut atv tire
repairing cut in atv tire
sti c7 wheels
nasty grinding, front left tire cooper99 ATV Repair and Maintenance 3 05-11-2011 02:16 PM
98 sportsman 500 right front tire not spinning Tom Kimmel Polaris Sportsman 1 02-07-2011 07:49 AM
Front tire chains JET Polaris Sportsman 7 12-31-2010 06:15 PM
350l 4x4 only one front tire spins in 4wd jeepster651 ATV Repair and Maintenance 1 08-23-2010 05:39 AM
Front tire lean? Fatguy55 ATV General Discussion 4 05-11-2010 07:34 AM
