Morning Ryan!
Are you sure about that size of your front tire? Stockers are usually 8" wide sometimes 9" wide. But 10" wide will rub with factory rims.
To answer your question no I do not think these tires will fit and 100% clear if your running stock Back Spaced rims. BUT a set of 1" spacers WILL allow you to run them WITH 100% clearance! You could also just buy new rims and get the same clearances.
BTW the GBC Spartacus is a excellent choice!!
