Old 09-13-2011, 04:37 PM
skizmo's Avatar
Member #13773
Help with wheel offset...cuz I have no freekin clue
OK, so I have a chance to buy ss112 for $70 cdn per rim regular $130...so its a good deal....my question is what the heck does offset mean and how does it apply...currently I have stock rims with front 27-9-14 rear 27-11-14 swamp lights...the rims available are 4+2 offset/5+3 offset/3+5 offset....there is only 2 available in each offset...so I need to no what 4 to buy and how this will effect the handling of the bike.
thanx for your help guys!
Get Some!
2011 Sportsman 550 XP Camo
ATV Logic Rear Storage Pack
Fin Grip Gun And Bow Holder
Custom 2-Up Seat
Pure Polaris Hand Guards
27' Swamp Lights
Polaris Front Lock&Ride Box
Ricochet A-Arm Guards (Black)
ATV Superstore 3 way Hitch
Garmin GPSmap 62
Old 09-13-2011, 05:25 PM
Offset is how centered the part of the wheel where the hub bolts too.
A 4+2 means that the entire wheel is 6 inches wide. When you bolted this wheel to the machine, 4 inches of this wheel is to the inside, and only 2 inches of the wheel offset from where it bolts up to the outside.
Basically it affects how close the tire is to the strut, or how far it sticks out from the hub.
The 5+3 is 8 inches wide, with 5 inches of the wheel to the inside of the hub.
I don't know if you need spacers, you might, should be easy to measure beforehand.
The 4+2 should work on the front. ITP lists the 5+3 most for the XP. It also throws the 3+5 in there a few. Less chance you need spacers on the rear with the 3+5, but if the 5+3 fits with no rubbing issues, it's the better choice for the rears.
Old 09-13-2011, 09:48 PM
skizmo's Avatar
Member #13773
thanx blueline......i will be at the store for 9 am...sharp!....I hope I dont need spacers, those dam things aren't cheap.
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
atv wheel offset
atv wheel with 6 offset
atv wheels what does 4 2 offset mean
atv wheels without offset
define atv wheel offsets
is 5 3 offset ok for polaris
polaris atv stock wheel offset
polaris atv wheel specs
ss112 3 5 offset mean
what does 5 3 mean on a atv wheel
what is a rim offset on atv
what is offset meen for tires on quad
wheel offset for atvs
wheels atv polars 14'offsert 3 5
XP wheel offset question Thor ATV Wheels & Tires 11 01-28-2012 02:22 PM
Question on Wheel Offset DrnknCamel ATV Wheels & Tires 6 03-30-2011 10:14 AM
Wheel size/offset Rc4mike ATV Wheels & Tires 0 01-04-2011 06:37 PM
Wheel offset? Atglenhillbilly ATV Wheels & Tires 8 12-16-2010 06:42 PM
wheel offset bf750 ATV Wheels & Tires 3 12-02-2010 04:38 PM
