Old 09-14-2011, 03:54 PM
adamcr80123's Avatar
Member #18654
tire size question
i have a 2000 magnum 325 with stock tire size 24x8x12 and 24x11.5x12. Can i swap them for 25x8x12? Will there be any issues? Any answers would be great!
Old 09-14-2011, 06:18 PM
cwlongshot's Avatar
WELCOME!!
You should be fine with this increase in tire size.
Al tho the 325 is no power house the small increase in diameter shouldn't be too noticeable. The clearance at the fenders should be a non issue, as long as the springs are not excessively sagging. But be sure you keep the same tire widths as stock! As that's a bigger concern with clearance issues than diameter is.
Also, I advise against going with too aggressive of a tire. Like a Hi Lifter Outlaw or Silverback or similar heavy aggressively tread-ed tire. IF that IS the case, I would also look into a clutch kit. I usually suggest 2" of tire diameter increase, as a good place to begin looking at clutch kits. With the 325, I worry about the exceedingly small amount of power the Lil 325's has, (I have one too. 13 HP IIRC) could be quickly taxed with such an aggressive and heavy tire.
Old 09-15-2011, 01:15 AM
Member #18654
Thanks, they're not to aggressive of a tire, im just able to get a good deal on these and was hoping they would fit. would changing to an 8 in the back be to narrow or would that help a bit?
Old 09-15-2011, 04:02 AM
cwlongshot's Avatar
I am sure it would, but fear the repercussions for the loss of floatation would be more offensive. Personally I would not want less than a 10" tire out back and an 11'' would be better...
The old philosophy was a tall skinny tire for mud to get down to the solid ground beneath... But what if the mud is too deep that a tall enough tire is not practical? A wide tire offers flotation on all surfaces. Its better for the environment as it spreads out the surface area and disturbs less earth. We air down our tires for a greater contact patch, in to gain traction and cause less destruction to the trails. Starting from a skinny tire this is less effective.
2000 polaris 325 tire size
2000 polaris trail boss 325 tire size
24x11.5x12
24x11.5x12 tires
atv tire dia increase
horsepower polaris 325
polaris 325 magnum tire size
polaris 325 magnum tire sizes
polaris atv spred red coustom
tire size for 2000 magnum 325
tire size for trail boss 325
Help with tire size? flht38 ATV Wheels & Tires 5 08-21-2011 06:10 PM
09 850 XP tire size question. JustinHEMI ATV Wheels & Tires 4 04-30-2011 05:12 PM
Newbie Tire Size Question!! Dont_Blink ATV Wheels & Tires 3 04-05-2010 04:06 AM
going down in tire size model70 ATV Wheels & Tires 6 03-23-2010 06:09 PM
Newbie Here- Gotta a Sportsman tire size question NH-Rider ATV Wheels & Tires 2 02-25-2010 04:14 PM
