Old 09-20-2011, 06:56 AM
MudLife500's Avatar
Member #13989
Exclamation 27" mudlites..will they fit?
I found a good deal on some 27x9x12 & 27x10x12 mudlites. Before i pick them up this weekend, i was wondering will i have any problems clearing these on my 2011 sp 500? i know i should be fine height wise, but what about width? Thanks
Old 09-20-2011, 07:17 AM
Mississippi_850xp's Avatar
Member #18015
They should clear I got 32 in silverbacks on my 850 with no lift and they clear
Old 09-20-2011, 08:30 AM
cwlongshot's Avatar
AHH.. but on what rims??
Your gonna need new rims with less back spacing OR spacers to move the tires out from under the machine...
THEN maybe think on a clutch kit....
Old 09-20-2011, 08:32 AM
MudLife500's Avatar
Member #13989
stock rims.. im gonna get spacers, but trying to do without for this weekend?
Old 09-20-2011, 10:37 AM
Member #18015
SS alloys 312 and no wheel spacers
Old 09-20-2011, 12:29 PM
MudLife500's Avatar
Member #13989
so the 27x9s wont fit in the front without rubbing the tie rods?
Old 09-20-2011, 12:35 PM
cwlongshot's Avatar
Wink
Originally Posted by MudLife500 View Post
So the 27x9s won't fit in the front without rubbing the tie rods?
Most likely yes. (But its close)
On my machine my 26x9 Big Horns would not clear. I simply bought and installed 1" spacers.
Some people find that flipping the TREs and re aligning gets them the needed clearance.
others also find for less than 1/8" more thick grade 8 washers on the studs gains them enough. (Grade 8 because they tend to be thicker. NOT for any strength gains)
Word of warning: Be sure you have long enough studs AND the fewer washers the better. (I don't like even mentioning it and personally would only use ONE washer per stud if I needed it.)
Old 09-20-2011, 12:44 PM
MudLife500's Avatar
Member #13989
thanks cwlongshot, i guess ill just have to see and worst case scenario ill put a washer for each stud on the front to get me buy til i order the spacers. but the spacers are fine for a temp fix? no risk of damage?
Old 09-20-2011, 12:51 PM
cwlongshot's Avatar
Some claim the spacers offer allot of leverage to the hubs and destroy bearings fast. While they are correct in that there is more leverage applied, I offer its no more than a rim with less offset would and very likely less! Besides, people buy new rims with out a single thought about the leverage...
We are talking minimal numbers here. Like 1" even a less BS rim would be 2" or more...
I would not worry.
Your quite welcome, I am happy to help,
27 mudlites
27x10x12 mudlites
28 mud lites
nwill 27 mudlights fit with stoch wheels
polaris mudlites
Mudlites for sale 700ryder ATV Parts for Sale 2 09-16-2011 05:07 PM
Tire pressure for ITP Mudlites?? mjscharlotte ATV General Discussion 2 07-07-2011 05:28 AM
ITP Mudlites mjscharlotte ATV Wheels & Tires 5 06-03-2011 04:56 PM
Mudlites XL`S or Bighorns? RubiconChris ATV Wheels & Tires 22 03-21-2011 07:43 AM
Polaris 700 Twin EFI... "Wait" and "End" Error? TechieSooner Polaris Sportsman 3 11-26-2010 06:20 PM
