Old 09-26-2011, 10:12 AM
Stretch's Avatar
Member #18111
28" zilla on 2003 polaris 700
what are my options to make the 28x10x12 maxxis zilla front tire fit on my 2003 polaris sportsman 700? I know I need a lift but what about the clearance on the strut tower? I want to use the factory wheels so I assume I just need some 1" spacers or am I wrong? right now I'm running the stock goodyear rawhide 25x8x12 and it appears to have about 1" of clearance with the strut tower. I was wondering about just turning the wheels backwards, is there a reason that wont work?
2004 SPORTSMAN 500HO (HERS) 2500 LB WARN WINCH WITH SYNTHETIC ROPE
2003 SPORTSMAN 700 TWIN (MINE) 3 Headlight mod, Reverse bypass mod, temp gauge, volt meter and 2" lift, 28x10x12 & 28x12x12 zilla's, snorkel, 2000lb champion winch, reverse light, K&N air filter. Yearly maint done Feb 2012
Old 09-27-2011, 10:04 AM
Stretch's Avatar
Member #18111
Anybody got an opinion?
Old 09-27-2011, 11:56 AM
cwlongshot's Avatar
I would bet you are correct, but not having don't this I cannot say with 100% certainty...
Old 09-27-2011, 12:20 PM
SMP63's Avatar
Member #13545
Get ready to get really dirty. I got a feeling the tires are going to stick way out of the fenders making the wheeler very wide!!! Also not sure how the wheel bearings are gonna like it. Won't know till ya give it a try!!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 09-30-2011, 11:17 AM
J10_Jimbo's Avatar
Member #4601
Running 28 Zillzs on an 500 HO, had to build spacers for strut clearance, 1.25", If I remember right.
As for turning the rims around, have done that also on the rear of a Honda Rancher, used a set of stock Brute wheels, what I had on hand at the time. The only thing I don't like is the stems on the inside, have not had a problem, but keep thinking a stick hung between the axle housing and wheel will cause one to break. Just make sure the stem does not rub the brake disc or parts when installed that way.
03 polaris 700 tire size
04 polaris sportsman 700 lift kit
2003 polaris 700 snorkel
2003 polaris 700 sportsman dimensions
2003 polaris sportsman 500 liftkit
2003 sportsman 700 snorkel
2004 sportsman 700 snorkel
2011 sportsman 500 28 tires
28 tire on sportsman 700
easiest way to lift a 03 polaris 700
how to make snorkel for sportsman 700
lift 2003 polaris sportsman
polaris sportsman 500 wheel spacers for 28 tire
poliars lift for 2003 700
snorkel for polaris for 2003 700
what size tire fit sportsman 700 with lift
wheel spacers for a 2003 polaris sportsman 700
wheel spacers for polaris 700 twin
27" zilla's Sharkbait ATV Wheels & Tires 8 09-27-2011 06:04 AM
26" Zilla's on stock wheels 2010sportsman500 ATV Wheels & Tires 2 08-18-2011 09:22 PM
sportsman 800 w/ 2" lift will 30" zilla's fit? QuickSilver74 ATV Wheels & Tires 3 01-21-2011 10:47 AM
Look at what the ITP fairy left me today (14" SS312's, 26" Zilla's) NickS ATV Wheels & Tires 23 10-20-2010 03:59 AM
'10 Sportsman 800 Zilla 28" Tires thinblue86 ATV Wheels & Tires 9 09-27-2010 01:42 PM
