Old 09-26-2011, 07:07 PM
Shane_Bohnert's Avatar
Member #19064
2008 800 tire sizes???????
Can I put a 26-10-12 mud lite on the front of my sportsman without a spacer???? The factory tire is 26-8-12.
Old 09-26-2011, 08:06 PM
Old 09-27-2011, 03:38 AM
cwlongshot's Avatar
WELCOME!!
If you mount them on the stock rims, It will bolt up, but it will very likely hit the TRE and possibly the strut. If it clears by say 1/4" or less, it will still make contact in turns and rip up the fragile TRE boots. In order to run them you will need at least a thin spacer or different rims.
Generally speaking 10" tires will not "clear" on stock rims.
Old 09-27-2011, 06:25 AM
Member #19064
Thanks for your help!!!!
ok another dumb question to I want 1 1/2 inch or 2 1/2 inch spacers and all 4 tires or just tjhe front 2?
Old 09-27-2011, 10:50 AM
cwlongshot's Avatar
Wink
I doubt you will require more than a 1" spacer at each wheel...
08 can am 800 outlander rear tire size
08 sportsman 800 tires hit
08 sportsman 800 tires size
2008 polaris sportsman 800 tire size
2008 sportsman 800 tire size
polaris what size wheel spacers do i need for 26-10-12 26-12-12
sportsman 800 tire sizes
what is stock tires size on polaris sportsman 800
2008 800 tire sizes??? Shane_Bohnert Polaris Sportsman 3 09-27-2011 06:27 AM
tire sizes jma3082 ATV Wheels & Tires 1 06-19-2011 07:12 AM
tire sizes jma3082 ATV Wheels & Tires 1 04-16-2011 05:51 AM
tire sizes jma3082 ATV Wheels & Tires 5 02-25-2011 05:19 PM
Tire sizes Muggin ATV Wheels & Tires 1 02-16-2011 03:13 AM
