Old 10-11-2011, 04:49 AM
Dryrider's Avatar
Member #19476
Can't get an answer!
I have a 1997 Polaris xplorer 500 it has 25x12x10 on the rear and 25x8x12 on the front I'm told all are 4/156 bolt pattern. I found a set of tires and rims off a Razor for sale really nice! But no one knows the offset! How will these change the width of my machine? I even called a dealer! Any help? Thank you kindly!
Old 10-11-2011, 04:57 AM
Dryrider's Avatar
Member #19476
This is the post of what I want to buy2 front tires 25x 8.00-12 2 rear tires 25x10-12 Factory take offs fits rzr, sportsman and rangers 5 miles on tires. I placed the tires next to our sportsman that has 26 inch tires and they are the same height.
Old 10-11-2011, 05:12 AM
cwlongshot's Avatar
What are the rims? Steel or alloy?
I bought a set of alloys off a RZRs I needed a little extra space as the tires where 12 wide out back and 9 in the fornt as opposed to 11 out back stock and 8 in the front. SO I bought 1" spacers and I was good to go!
Old 10-11-2011, 05:28 AM
Dryrider's Avatar
Member #19476
Must be alloy pretty fancy looking for steel. I'm told could be an issue with rear lug nuts flange vs flat? How much would these spacers cost?
Old 10-11-2011, 05:39 AM
Dryrider's Avatar
Member #19476
I'm not at the same location as my ATV right now it's at the farm 100 miles south of me. Was hoping to buy these today sellers says 4 1/2 and 6 1/2 offset? Will I need spacers?
Old 10-11-2011, 05:44 AM
Dryrider's Avatar
Member #19476
I have looked through 8 pages of posts still no luck with finding an answer 1997 is pretty old like me
Old 10-11-2011, 06:05 AM
SMP63's Avatar
Member #13545
Mornin!! Just checked a sponsors site & spacers run from $90 to $120 a set.
Lug nuts to fit the rims around $30. I suggest giving Thor a call & he can probably get them cheaper & answer your questions.
Hey! ATV Parts and Accessories are Here
CW has his phone # in his signature!! Wheel off set aint my cup of tea!
Hope this helps & post up results if you would!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 10-11-2011, 06:25 AM
Dryrider's Avatar
Member #19476
Found your post looks like I need longer studs or spacers?
Old 10-11-2011, 06:28 AM
cwlongshot's Avatar
Good catch,
sorry I should have mentioned the lug nuts AND STUDS!!
See Polaris chose to make TWO different length wheel studs... Longer ones are for alloy wheels and WILL be required if yours are the shorter steel variety.
Then also a YES alloys use a automotive "acorn" style. Where as the steel rims use a captured flat washer style that will NOT work on the alloys.
I bought one set of mine at the dealer and another online thru EBay. IIRC 50$ a set of two...
Also YES the lug spacing on the RZR rims is four holes in a 156mm circle. Now a standard for Polaris machines. Some older solid axle Polaris machines had a four on four bolt circle.
This is the rim style I bought:
The back spacing is, 4.5" in the front and 6" in the rear rims. Again these are off a 2010 RZRs.
Good luck,
Old 10-11-2011, 06:39 AM
Dryrider's Avatar
Member #19476
That's the rim I'm looking at...very nice!! I called Thor he was not sure because of the year of my ATV (1997) so still not real clear on what I might have to do... But boy I hope I can make them fit? Wow that nice!
4x4 to 4x156 wheel adapter
polaris xplorer wheel stud
polaris xplorer wheel stud size
wheel back spacing on stock polaris xplorer wheels
Sealing my clutch box or CVT 850XP ANSWER PLEASE crimson850 ATV General Discussion 6 03-17-2011 02:40 AM
Please Help answer my ??? here i have to get it fixed today Heavy Sausage ATV General Discussion 0 11-14-2010 05:50 AM
Need quick answer. disco ATV Repair and Maintenance 5 08-17-2010 05:42 PM
I searched for an answer first! loftgolf ATV Repair and Maintenance 2 04-27-2010 03:42 PM
A-arm swap answer for jeff3541108 blueline15 Polaris Scrambler 4 03-16-2010 04:16 PM
