Old 10-12-2011, 04:57 AM
IndyRed800's Avatar
Member #19189
Wheel Weights & Offsets
Does anyone know how heavy the standard Sportsman 12x6 & 12x8 sportsman wheels are? I'm trying to compare the factory wheel weight against aluminum aftermarket wheels.
I am also looking to install 26x11 Tires in the front on 12x7" wheels. I am wondering if I can get away with 5+2 off set or would i have to go to 4+3 offset? I know the factory wheels in front are 12x6 with a 5+1 offset, so I was hoping the extra 1" of B.S would clear 11" wide tires but possibly not...
I imagine that a 4+3 offset would be hard on the wheel bearings?
Shawn
2011 Sportsman 800 EFI
Pure-Polaris 2500lbs Winch w/ 50' Amsteel Blue Synthetic Winch Rope, & UHMW Synthetic Roller Fairlead w/ Winch Saver
Pure-Polaris Lock & Ride Low Black Windshield
Pure-Polaris Lock & Ride Front Cargo Box
Pure-Polaris Glacier II Plow System w/ 52" Snow Blade
Pure-Polaris Sportsman Trailerable Cover
Old 10-14-2011, 06:41 AM
IndyRed800's Avatar
Member #19189
I havn't gotten any hits on these two questions so I re-worded what I am looking for in my original post.
Shawn
Old 10-14-2011, 08:51 AM
IndyRed800's Avatar
Member #19189
By what I've been told the Factory wheels 12x8 are 10lbs, and 12x7 are 8Lbs. Factory cast Polaris Wheels weigh as much if not more.
Shawn
Old 10-14-2011, 03:34 PM
racer37l's Avatar
Member #5629
I think your going to find that to install wide tires on the front you will have to use fairly wide spacers. At least 1 1/2 to 2".
Con
Old 10-14-2011, 04:28 PM
cwlongshot's Avatar
To what end? I mean why the questions...
ANY wider tire than stock will exert more stress on the suspension. ANY difference in offset will do the same... BUT don't get all caught up in so called "problems" that may or may not ever be a problem. Countless numbers have installed and run wider tires with less back spaced rims with no problems...
Look at it this way.. riding in allot of mud is FAR more damaging to the machine. Aggressive riding can exacerbate the problems.
Back to my first question.. what are you wanting to do or get to...
Old 10-15-2011, 08:43 AM
IndyRed800's Avatar
Member #19189
Here is my reasoning behind looking for a wide front & rear Tire Combo:
1. I am a trail rider, but being way up in Northern Ontario our spring/summer/fall trail riding are on marked OFSC Snowmobile Trails. Unlike ATV trails we are subjected to alot of muskeg, swamps and black muck. But 50% of the trails are awesome with hard packed ground.
2. Because I do trail riding & Road use I can't move up to a tire such as the silver back or Outlaw, Mudzilla. I am also looking at a Radial Tire that needs to do well in the Snow.
3. Since I can't make up for my needs in Tread design I need to gain flotation in other forms and the large front tires came to mind.
I just question how this will effect ride, and steering. My tire of choice is the Maxxis Big Horn Radial if that helps. I'm alos wondering what effect this will have on wheel bearings, axles..etc..
I'm just looking for feedback...
Shawn
Old 10-15-2011, 09:05 AM
2sportsman700's Avatar
Member #19354
i have a 05 700 with 12x8 rims with 27x12x12 mud machines tri claw all the way around without any issues
Old 10-15-2011, 09:09 AM
Member #19354
they pull good we ride in a lot of swampy stuff here in louisiana and ride good on hard packed ground
Old 10-15-2011, 09:15 AM
racer37l's Avatar
Member #5629
As you can see, I use the Bighorns s/w on my bike. Last winter I used it to plow a lot of snow. And ride quite a bit. No problems what so ever!
Con
Old 10-15-2011, 10:50 AM
IndyRed800's Avatar
Member #19189
I appreciate the feedback. Do you know what offset your wheels are? and if you needed to run spacers on the front?
Also do you have any pictures, I'm willing to bet that looks pretty effin good!
Shawn
2000 polaris sportsman wheel size
4 3 offset for polaris sportsman rims
atv wheel weights for plowing
atv, front weights
best offset for wide tires on sportsmen
factory atv wheel weight
factory offset for 2007 polaris 800 sportsman
maxxis black crusher wheels offsets
offset for stock polaris rims for 2007 sportsman
polaris atv weights
polaris sportsman 800 wheel offset
polaris sportsman 800 wheel pattern
polaris sportsman front wheel offset
polaris sportsman stock wheel weight
sportsman 12x7 4 3 offset for 10 wide tires
stock 2007 polaris sportsman 800 wheels offset
weight different stock vs aluminum rims atv
what is the size of a stock front wheel for a 2007 polaris sportsman
what is the stock offset on a 2007 polaris sportsman 800
Orange Primary spring & 47 gr weights Gear_Head ATV Parts for Sale 4 09-28-2011 06:23 PM
Are these the right offsets for my xp all out ATV Wheels & Tires 1 04-16-2011 05:49 PM
2000 335 Sportsman drive clutch weights Thor2911 ATV Repair and Maintenance 0 03-20-2011 03:59 PM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 Polaris Scrambler 2 02-15-2011 04:22 AM
Should i be lifting weights? keetmanaa ATV New Members 4 09-14-2010 12:34 PM
