Old 10-13-2011, 03:57 PM
lod666ftw's Avatar
Member #14566
Zillas and Snow?
Im thinkin of getting Zillas for my 850 Xp. Im wondering if anyone knows how they run in snow and actual tire size vs advertised size? I know alot of people run them and I really like the weight advantage they have vs the typical radials out there of same advertised size!
2011 850 XP pursuit camo
26" Sedona Ripsaw Tires
Lock and ride front box
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
Old 10-14-2011, 01:49 AM
North Branch's Avatar
Member #1986
We have a guy that rides with us that ran Zillia's when he had his XP. He liked the Zillia's and they seemed to go fine in the snow. He certainly kept up with everybody else. Although, he commented that the Zilla's will "dig" a hole if you are hard on the throttle. They also run small. He got the 27", and they were just barely larger than the stock 26" tires. Probably one the reasons they are light in weight.
HTH
Old 10-15-2011, 06:23 AM
lod666ftw's Avatar
Member #14566
I have seen so many posts on Zillas on here I cant believe I cant get anymore info? Thanks for the input North Branch!
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
Old 10-15-2011, 10:09 AM
Member #1986
No problem man. Maybe someone else will stop by with more info.
I see where you are coming from... those Rip Saw's are probably a pretty heavy tire. Another decent snow tire to consider would me the Bighorn 2.0. They are lighter than the original Bighorns, and will be considerably lighter than the Rip Saws, and run pretty much true to size. They won't have near the the tread depth that your Rip Saw's have, but you don't want than anyhow for snow riding. You need a tire that will "float" on top of the snow like a snowshoe. Something with less of an aggressive tread design and a flat footprint.
Good luck.
Old 10-15-2011, 10:30 AM
lod666ftw's Avatar
Member #14566
I hate those ripsaws, there to much tire! Dont get me wrong they will go through anything but there far from what I wanted and Yes they are to heavy, 41 and 49 lbs mounted on stock steel wheels front and back!!!
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
Old 10-15-2011, 10:55 AM
Member #1986
So are you looking for new tires to completely replace the Rip Saws... year round, or are you going to keep them, and run something different in snow?
Old 10-15-2011, 10:59 AM
lod666ftw's Avatar
Member #14566
Yea, I took my ripsaws off and there in the shed.Im running the stock tires and just cant get over how much better they ride. I Hate the stock tires too!
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
Old 10-15-2011, 11:04 AM
Member #1986
Well then, I'm not sure exactly what type of tire you are looking for (other than lighter), but there are a number of tires that will weigh considerably less than the Rip Saws that are great "all around" tires.
What type are you looking for? What type of terrain do you ride in most of the time.
Old 10-15-2011, 11:17 AM
lod666ftw's Avatar
Member #14566
Ive been lookin at the usual, big horns, sparticus, reapers and zillas. I also like the dirt commanders even though there not radials. I really like the xtr's i have on my 01 500 ho but they ony make in 27's and the weight scares me. My stocks weigh 22 and 28 mounted on same wheels. I realize Im gonna gain but some I believe are to heavey. I ride mostly hard packed trails. I get in mud once in awhile, try to avoid alot of it. Typical pennsylvania trails and snow. Just alittle of everything but sand!
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
Old 10-15-2011, 11:29 AM
Member #1986
OK then... yea, Big Horns, Spartacus, Grim Reapers are all good. However, last week I had to change to ride my buddies quad with his new skins. Today, he had the quad over my place and we changed out all the fluids. While we had it up on the lift, we pulled his rims and tires and threw them on my quad just so I could compare them to my Big Horns. I was quite impressed, and liked them even better than my Big Horns. Very smooth ride. Handled and steered great, and went through my creek, up a steep side hill and over a bunch of rocks and downed timber on my property.
They are a new relativity new tire from Kenda called the Bear Claw HTR or Bear Claw II. They are 8 ply rated radials. I looked up the specs, and they are actually a tad lighter than my Big Horns, which are probably lighter than the Spartacus and Grim Reapers.
Here's a link...
Kenda - Bearclaw HTR
So, there's another one to throw in the mix.
actual sedona tire measurements
bighorn versus ripsaw tires
do bearclaws tire run true to size
do sedone ripsaw tires run true to size
ripsaw tires review
sedoa ripsaw vs bear claw
sedona rip saw actual height
sedona rip saw reviews
sedona rip saw specs
sedona rip saw tire specs
sedona rip saw tires true size
sedona rip saw vs bighorn 2.0
sedona ripsaw atv tire reviews
sedona ripsaw reviews
sedona ripsaw sand reviw
sedona ripsaw tires true size
sedona ripsaw vs zilla
sedona ripsaws vs zillas
what is the weight of a sedona rip saw 26-11-14 weigh
zillas for snow
30/11 zillas`s on 112`s OHH YEEAAHH eracrzr ATV Wheels & Tires 16 08-10-2011 08:33 AM
anyone running 30'' zillas on a 500 ho? jwiggin3021 ATV Wheels & Tires 4 03-23-2011 01:24 PM
Zillas, Anyone? eclifford634 ATV Wheels & Tires 5 01-10-2011 06:44 PM
Bighorns and zillas SNW629 ATV Parts for Sale 7 07-10-2010 07:14 AM
30" Zillas messinaround ATV Performance Modifications 0 04-30-2010 12:24 PM
