10-16-2011, 09:21 AM
Member #16794
XP Aluminum wheels on 2010 Sportsman 500
What will I need besides tapered lug nuts to make these work? Will the studs be long enough? Will I need spacers? Any help is greatly appreciated!
10-18-2011, 09:26 AM
Member #16794
Ok I figured it out. Just need 2" spacers and tapered lug nuts
10-18-2011, 05:09 PM
Member #11247
Looks good!
2011 Trail Boss - HIDs SOLD
10-18-2011, 05:16 PM
Member #5254
That looks awesome!! Thanks for posting.
Thanks,
Will
2004 GMC 1500CC Z71.
11-11-2011, 06:36 AM
Member #2669
i like your pic. those wheels look good on your machine. i have an 2001 sportsman that i was thinking about throwing a set of xp wheels on. i know you said that you had to get 2 inch spacers but what type of tapered lug nuts? did you have to get them from polaris? if you have any more pics please post them.
thanks!
Ransom Proctor
2010 Polaris Sportsman 850 Touring with EPS
2012 Polaris Ranger 800 Sunset Red LE with EPS
2007 Sportsman 450
2006 Predator 90
11-11-2011, 02:16 PM
Member #19436
looks good!
11-12-2011, 11:47 AM
Member #16794
thanks!
Sorry don't have any more pics at the moment. I went with lug nuts like this:
2007 Sportsman 500 EFI Deluxe Polaris ITP Lug Nuts - 3/8in - Tapered - Chrome | eBay
11-21-2011, 08:57 AM
Member #2669
do the tires stick out much? what brand of spacers did you go with? i've never put wheel spacers on anything, just wondered. i ended up buying a 2007 sportsman 450 that looks almost identical to your 500. the xp wheels are going to look sweet on it.
Ransom Proctor
2007 Sportsman 450
2006 Predator 90
11-21-2011, 02:46 PM
Member #16794
The tires actually sit exactly where the stock tires sit without spacers. No sure on the brand of spacers just make sure the outer surface where the rim sits is smooth and doesnt have the ledge where the steel rim would sit.
2010 polaris sportsman 500 wheel spacersd, 2010 sportsman 500 wheels, 2011 polaris 500 ho lug nut size, aluminum polaris factory on sportsman wheels ok, aluminum rims to fit a polaris atv, factory polaris sportsman 500 aluminum wheels for sale, factory wheels for 2010 polaris 500 sportsman, make xp wheels fit sportsman 500, polaris factory wheels, polaris wheels for 2010 sportsman 500, polaris xp 14 rims sale sportsman, sportsman 500 lug nuts, sportsman 500 wheels, tapered standard lug nuts sportsman, what size lug nuts go on a polaris sportsman 500, what size wheel nuts on 2011 sportsman 500, wheel bolts not long enough#gsc.tab, will 2011 sportsman stock rims fit a 2007 sportsman, xp sportsman wheels fit a 500 spacers, xp wheels
