Old 10-22-2011, 03:50 PM
Imhambone's Avatar
Member #19700
Do I need different lug nuts for Aluminum rims
I just purchased a set of Aluminum rims for my 09 Sportsman 500 to replace the stock steel rims. Do I need different lug nuts and or spacer for the aluminum rims? Any help is greatly appreciated. Ken
Old 10-22-2011, 06:46 PM
racer37l's Avatar
Member #5629
Welcome!
What wheels have you purchased?
Con
Old 10-22-2011, 07:16 PM
Imhambone's Avatar
Member #19700
Thanks, Sedona Mud Rebel on ITP rims.
Old 10-22-2011, 07:55 PM
SMP63's Avatar
Member #13545
Welcome to the forum!! Yes you will need new lug nuts! ITP makes'em. Use them for my STI wheels. Depends on tire size as far as spacers go. Test fit the tires on the bike & see if theres clearance @ the tie rod ends. Your gonna want @ least 1/2" clearance. 1" is better!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 10-22-2011, 08:40 PM
Imhambone's Avatar
Member #19700
I thank you for the reply. That was what I suspected, looks like I may need a tapered lug. I've got them on the ATV and they look good but the steel lug nuts just didn't feel quite right.
Old 10-23-2011, 08:10 AM
dyna105's Avatar
Member #19421
Inhambone,
My understanding from reading a few dozen threads on this forum. You may need to change the studs also. Seems they use a longer stud for the aluminum wheels. Hey new studs and nuts for the way new wheels will look, that's just a small price to have to pay...hehehe
Old 10-23-2011, 04:41 PM
SMP63's Avatar
Member #13545
Originally Posted by dyna105 View Post
Inhambone,
I did not need longer studs. The stock ones work fine!!!
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
2011 polaris 500 lug nut
atv lug nut caps
atv steel rims vs aluminum
different lug nuts for aluminium wheels?
different lug nuts for aluminum wheels
different lug nuts for steel and aluminum
do aluminum wheels need different lug nuts
do i need diferant lug nut for alluminum rims polaris
do i need special lug nuts for 10 alum wheels
do i need to change lug nut
do new lug nuts need new studs
long atv lug nuts
lug nut
lug nutt size polaris 500
polaris lug nuts
polaris lug nuts for itp rim
polaris vision wheel lugnuts
sti polaris lugnuts
stock polaris steel wheel lug nuts
which way lug nuts aluminum wheels
Black Aluminum Rims Camo850xp ATV Wheels & Tires 3 09-23-2011 07:21 AM
2010 stock xp aluminum rims f/s all out ATV Parts for Sale 3 04-17-2011 04:35 AM
Stock XP rims; aluminum vs. steel misterjlk ATV General Discussion 3 04-11-2011 03:49 AM
WTB: Polaris Aluminum Rims secondsole ATV Parts for Sale 3 01-24-2011 05:28 PM
Nuts!! tderrick ATV Repair and Maintenance 15 10-31-2010 06:47 PM
