10-23-2011, 06:15 PM
Member #10990
tire question
hey guys been a while since ive been on here
i have a question about ordering some tires for my stock rims.
I am looking into purchasing some kenda executioners and i want to keep the stock rims,
the fronts come in the same size as the rims but the rears are 25x11x12(stock)
would i be able to fit 25x10x12 or 25x12x12?
i found a great deal on the executioners and im really looking to stay in the $350 Price Range.
thank you
2010 Sportsman 500 H.O.
Pure Polaris Hand Guards
Front & Rear Rack Extenders
Rear Mad Dog Cargo Bag
Pro Mark Winch(KFI Plate)
(Ebay Front and Rear Bumpers)
10-23-2011, 10:57 PM
Member #16947
You shouldnt have a problem running those on stock rims. How wide are your stock tires? You will love having some extra width in the rear, I am running a 12" wide tire in the on both of my bikes. But I do have aftermarket rims too.
2006 Sportsman 500 EFI
-28" Outlaws, Rad relocate, QSC kit, snorkeled, ODI grips, 4 speaker stereo.
2005 Yamaha Grizzly 686 BBK & Mudbuster cam
-28" Outlaws, Rad relocated, Snorkels, Exhaust snorkel, fan over ride switch, clutch kit
2009 Polaris RZR LE--27" Mudzillas, snorkels
10-26-2011, 10:10 PM
Member #10990
The set I am looking at has the rears at 25x10x12, my friend has the same ones on his grizzly and he loves em and they are plenty wide. Im just curious as to whether the 25x10x12 tires will mount on the stock rims which the stock tires are 25x11x12. The tire lingo doesn't make sense to me.
Sent from my DROID3 using Tapatalk
10-27-2011, 05:48 AM
Member #19189
25X10-12 Will mount on the rear no problems at all. 25X10-12 will not mount on the front. You will need 25x8-12 for the front. Actually a 25-10-12, 25-11-12 and 25-12-12 will mount on the rear, but you can't go more then 8" wide on the front without going with spacers on the front wheels.
Shawn
2011 Sportsman 800 EFI
Pure-Polaris 2500lbs Winch w/ 50' Amsteel Blue Synthetic Winch Rope, & UHMW Synthetic Roller Fairlead w/ Winch Saver
Pure-Polaris Lock & Ride Low Black Windshield
Pure-Polaris Lock & Ride Front Cargo Box
Pure-Polaris Glacier II Plow System w/ 52" Snow Blade
Pure-Polaris Sportsman Trailerable Cover
10-27-2011, 06:50 AM
Member #9763
^^^ What he said.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
10-27-2011, 12:40 PM
Member #16794
I'm going to order a set of these as well but I've heard the executioners run small so I was was going to order 26" tall instead of 25". Does anybody know if they actually run small? If they are actually 26" will they fit a stock sportsman 500?
10-27-2011, 02:59 PM
Member #19189
If the wheel wells on the 2010 are similair to the 2011 you should be able to stuff 28" tall tires under that 500 no problem. I wouldn't worry about 26" tires they will clear easy!
My buddies 2006 500 Sportsman clears 27" ITP mud Lites no problem.
Shawn
10 wide on stock wheels, 25x11x12 fit on a 25x10x12, 25x11x12 wide rim, atv 25-11-12 will 25-10-12 fit, can a 25x10x12 fit stock honda wheels, can i use a 25x10x12 tire on my 25x11x12 atv wheels?, can you run a 25x10x12 on the front of an atv, how wide of a tire can i get on my stock rims polaris, mounting 25x10x12 tires on 25x11x12 rims, what size of rim can a 25x10x12 fit on, why did polaris go to a 10 wide tire on the sportsman instead of 11, will 12 in wide tire fit on front of polaris 500, will 25x10x12 fit in place of 25x11x12, will 25x10x12 tire fit on 25x11x12, will 25x10x12 tires fit on 25x11x12 rims, will 25x10x12 tires fit polaris 500 atv, will 25x11x12 tires fit 25x10x12, will a 25x10x12 atv tire fit on a 25x11x12 rim, will a 25x10x12 tire fit a 25x11x12 rim, will a 25x10x12 tire fit on a 11 atv wheel
