10-29-2011, 12:15 AM
Member #20001
26" zillas on 2010 sportsman 500
I'd like to know if I will have any clearance issues with having this tire and size on my stock machine and using my stock rims. I won't be doing any lifts or adding spacers. The 26" zillas will be a 9" on front. I am wondering if the 9" front would be an issue with no spacer.
10-29-2011, 05:34 AM
10-29-2011, 07:04 AM
Member #5629
Welcome!
The only issue that you might run upon is the tire rubbing the tierod end. As your stock tires are 8" wide and you want a 9" tire, take a close look between the stock tire and tierod end. This will give you an idea if the 9" tire will clear without spacers.
One solution is to put longer studs in your hubs and use 3/16" or 1/4" spacers. Unlike the larger spacers, this should give you the clearance you'll need. And be cheaper.
One other thing, the zillas will run short, so think about the height if you want to stay close to stock.
Con
10-29-2011, 07:30 AM
Member #20001
Welcome!
Thanks for the reply.....
If they run short than that would mean i would have to go up to a 27" tire then? or if i stayed with the 25" they would be shorter than stock? Does anyonw make a tire true to what they claim it to be?!
10-29-2011, 07:35 AM
Member #5629
There are several tires that will run true to size. However, you need to know how you are going to use your bike to choose the right tire for your application.
Con
10-29-2011, 07:37 AM
Member #20001
Trail riding.....some mud bogs now and then.....but mostly trail riding
10-29-2011, 07:38 AM
Member #20001
I like the zilla but would most likely go with the 25" tire....but if i did then i would lose some hight i guess??
10-29-2011, 08:07 AM
Member #5629
I'd go with the 26" as it will probably be closer to your stock tires. These will be great for trail and some mud mixxed in.
If you run into a problem with clearance, check with Paul at Rubberdown Customs, as he offers 3/16" and 1/4" spacers that will probably be enough for what you need. (He is located in Niagra Falls on the Canadian side)
I have a set of 10" wide tires that I use in winter and I am going to get a set of the 1/4" for my bike as I already have the long studs.
Con
10-29-2011, 08:10 AM
Member #20001
These spacers you speak of.....they are just normal flat washers?
10-29-2011, 08:29 AM
Member #16228
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
2010 sportsman 500 zilla, 26 or 27's on sportsman 500, 27'' zilla sportsman 500, polaris sportsman 500 wheels and tires, polaris sportsman on zillas, sportsman 26 tire, sportsman 500 12 rims, sportsman 500 best wheels and tires, sportsman 500 zillas
