Old 10-29-2011, 01:33 PM
Rabbit's Avatar
Member #19965
Wheel size???
Im planning on buying new tires.. havent decided if i want to stay stock size which is 25X10-12 Rear, 25x8-12 fronts. or if i want to go bigger, but i wont go any bigger then 26x12-12 Front and 26x10-12.
So i want the cheapest WHEELS i can find, so i can easily go back and forth to stock when my aggressive tires arent needed.
So my question is
Which set of wheels, do i need to be able to fit those different sizes tires?
What size Wheel will fit 25x10 and 26x12 Rear, and 26x10 and 25x8 front?
Cheapest after market wheels suggestions welcomed.
Old 10-29-2011, 01:48 PM
racer37l's Avatar
Member #5629
Here is one:ITP TIRES - The World's #1 ATV Aftermarket Tire & Wheel Source :: Delta Steel
Con
Old 10-31-2011, 09:40 AM
Discount Tire's Avatar
Member #11270
You can search here for all the wheel that will fit your ATV. Just plug in the year make and model.
ATV Wheel Search - Discount Tire Direct
Let us know if we can assist you.
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door: www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Useful Links:
Shop ATV/UTV Tires
Shop ATV/UTV Wheels
Current Promotions
25x10-12 tires on 25x8-12 rims
25x8-12 polaris rims
26 12 12 rim size
26x12-12 wheel sizes
polaris rims size
polaris sixr rims offset
polris 10 tire what size wheel
what size is rim if its 26x12-12
what size rim does a 25x8-12 fit on
what size rim for 26x12-12 tire
what size rim for a 26x10-12
what size rim is a 26x12-12
what size rims 25x10-12 tires
what size wheels do i want for 25x10-12?
wheel size 25x8-12
wheel size to fit 26x12-12
wheels that fit 25x8-12
why are my atv wheels different sizes?
why different size wheels on my atv?
will 25x10 tires fit on 25x8 rims
how big over / under stock wheel size can you go? eichhoma ATV Wheels & Tires 4 12-10-2011 03:04 AM
Tire and wheel size help rogercar07 ATV Wheels & Tires 1 04-27-2011 05:41 PM
wheel size/ spacing. Tikldshitless ATV Wheels & Tires 2 04-04-2011 03:55 PM
Wheel size? ENCORE ATV Wheels & Tires 1 02-14-2011 01:02 PM
Wheel size/offset Rc4mike ATV Wheels & Tires 0 01-04-2011 06:37 PM
