Old 11-07-2011, 03:23 AM
SELYPB's Avatar
Member #19486
Need help with tires
I have a bone stock 2010 850 XP and want to get some better tires. I have the black steel factory rims and would like to actually keep those. If I can go up to a slightly bigger tire (27 - 27.5) I'd like to, but I don't want to have to put spacers on so I'm not sure if this will all be possible. My riding is basically trails with rock, dirt, and a few shallow mud holes. Would like to get these in the next couple of weeks and head over to Hatfields in WV.
The tires I've had my eye on are the GBC Grim Reapers, GBC Spartacus, and the Pitbull Rocker XOR. I want something aggressive, and to be honest with you I like the look of all three of these tires. I know how a tire looks doesn't really mean how it will do, but it does matter to me. I like the big lug aggressive looking type tires, makes the bike look a little meaner.
Just out of curiosity if I need a different wheel to go up to the 27 - 27.5 tires what would you recommend? Is there a certain off set I should get?
Thanks guys
Old 11-07-2011, 05:34 AM
sgtpatiolantern's Avatar
Member #19332
Most tire manufacturers have guides online which point out the strengths of each of their offerings. This may be the best route to follow. As far as the look of the tread, I have similar thoughts about the look of tires. My stock tires, albeit adequate, look like they were taken off a little girl's quad. Kinda takes away from the overall look. I have seen some tires that look ridiculously aggressive and I have wondered if they actually help. Those who own them seem to think so. Are they bulls**tting me to save face after getting hosed, or are they really that awesome? Only they will ever know. In my opinion, I can't see how a more aggressive tire wouldn't be better off road. Seriously....
2011 Sportsman XP 850 EPS
Nicknamed "KATT" (Kickass All Terrain Toy)
Polaris Lock & Ride Front Storage Box
Polaris Lock & Ride Rear Storage Box
Polaris Deluxe Front Brush Guard
Polaris Deluxe Rear Brush Guard
Polaris Handle Bar Guards
Polaris Lock & Ride Back Rest
Polaris 3500lb Winch Kit
Polaris Winch Accessory Kit
Polaris Wireless Winch Remote
Polaris Trailerable ATV Cover
Polaris Hand Warmers
Polaris Thumb Warmer
GoPro HD Helmet Hero Camera
"I fire up the willing engine,
Responding with a roar.
Tires spitting gravel,
I commit my weekly crime..."
Old 11-07-2011, 03:58 PM
up_a_tree's Avatar
Member #17615
Good thoughts, sgtpatiolantern
I poured over these archives when i concluded I needed new tires to take on H-M Rockhouse. and the looks are as important as the performance. I opted for the wider/flatter/blockier look of the Bighorn 2.0's (went with the 26"), and it immediately changed the personality/appearance of my '05 500SP HO. The wide lugs grip VERY well on all surfaces without tearing up the trail, and I got very positive comments on how well they looked on the machine. Many other riders @ H-M were using the Grim Reapers, and appeared to be satisfied customers as well.
I don't think SELYPB can go wrong on any of his tire candidates. You'll find strong support for most brands here, and he already knows what he wants his machine to look like.
Old 11-07-2011, 06:44 PM
PawPaw's Avatar
Member #962
Thanks guys
The '09's had trouble clearing the swaybar with wider tires like my 27x11's so I had to use spacer's in the rear. On your '10 they had a different swaybar so I think you should be OK with a 27x11 on the stock wheel's. I'd test fit one if possible to make sure.
Old 11-08-2011, 11:03 AM
Discount Tire's Avatar
Member #11270
You should be OK on the 2010 as they did move the sway bar.
You have picked 3 excellent tires. They are all 8 ply rated radial tires. They ride very comfortable and give awesome traction. Keep in mind the PitBull tires run 1/2 inch taller than the size indicates.
If you ride more mud I would go with the PitBull Growler's or the GBC Spartacus as this is what they are designed for.
Give us a call is we can help. Our number is 1-888-459-4080.
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door: www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Useful Links:
Shop ATV/UTV Tires
Shop ATV/UTV Wheels
Current Promotions
Old 12-19-2011, 07:10 PM
Mavrick 72's Avatar
Member #13764
Tire Size
I have an '09 and am aware of the issue with the sway bar. I was hoping to go with a different rim to fix this issue and put on a set of 27x11, but I have been told if you go up to a 27 I can loose quite a bit of power and should do some adjusting on the clutches? Is this correct? Is there athing on the bike that will need to be changed if I go up to 27?...........Thanks!
Old 12-19-2011, 07:44 PM
bobx2's Avatar
Member #14376
What are you riding, other than an '09? 550, 850? If it is an 850 it will turn the 27's just fine with no clutch work.
I just saw on another thread that you have an 850. You will be fine with 27's.
are 27.5 pitbull tires good for mud riding?
tires? 6jeff6 Polaris Scrambler 21 11-03-2011 04:47 PM
WTB Tires or wheels/tires and exhaust for 2001 Trail Blazer Ruined ATV Parts for Sale 2 10-19-2011 08:15 PM
Bias Ply Tires and Radial Tires… What’s what? What’s right for me? Discount Tire Discount Tire 2 08-03-2011 04:14 PM
WTB- Tires tekrsq ATV Parts Wanted 0 06-18-2011 03:21 PM
Atv tires svridersv ATV General Discussion 1 04-19-2011 03:50 PM
