Old 11-07-2011, 03:43 AM
Skierdad's Avatar
Member #7832
zilla sizing?
2008 Sportsman 500. currently running 26" Carlisle ACT's.
I noticed when I went from my stock carlisle 25" tires to the ACT's I lost a little bit of power so I was thinking of the zilla's as a backup for more mud riding. Sounds like the zilla's run small so does that mean the 26" is more like a 25" and the 9" is more like 8"? (would like to not add spacers if at all possible).
I have an extra set of rims so I can switch back and fourth.
It looks like I would drop 15 lbs going to the zillas from the ACT's.
One other thought.....Can I assume the zillas will be better in the mud than the ACT's, how about snow?
Thanks in advance for the help.
"Take a kid hunting instead of hunting for your kid"
2010 Tundra 4x4
2009 Moomba Mobius LS
2009 Polaris Ranger
2008 Polaris Sportsman 500
Old 11-07-2011, 04:22 PM
racer37l's Avatar
Member #5629
Zillas are a good all around tire. Yes, they do run short in height and I'm not sure how they run widthwise.
Con
Old 11-15-2011, 07:54 PM
Stretch's Avatar
Member #18111
my 28x10x12 front tires are actually 9" wide and about 27" once mounted on my 700 sportsman.
2004 SPORTSMAN 500HO (HERS) 2500 LB WARN WINCH WITH SYNTHETIC ROPE
2003 SPORTSMAN 700 TWIN (MINE) 3 Headlight mod, Reverse bypass mod, temp gauge, volt meter and 2" lift, 28x10x12 & 28x12x12 zilla's, snorkel, 2000lb champion winch, reverse light, K&N air filter. Yearly maint done Feb 2012
anyone running carlisle a.c.t. tires
big horn vs carlisle act
carlisle act vs big horn 2 on polaris sportsman
zilla vs bighorn
Tire to Wheels sizing Boodro ATV Wheels & Tires 3 11-03-2011 08:00 AM
27" zilla's Sharkbait ATV Wheels & Tires 8 09-27-2011 06:04 AM
Bighorn 2.0 Sizing Question? Skierdad ATV Wheels & Tires 16 03-22-2011 08:26 AM
Sizing Question eclifford634 ATV Wheels & Tires 3 01-04-2011 03:53 PM
maxxis zilla;s model70 ATV Wheels & Tires 10 05-07-2010 03:20 AM
